zetec turbo dry sump at what power ?
Old Mar 18, 2014 | 10:06 AM
s1cab's Avatar
s1cab
Looking at getting a dry sump i'm going to be running circa 450bhp on my zetec turbo. Read a few things here and there about oil pumps failing. So want to be safe and go for a dry sump set up. Which ones are good ? What's rhe difference between stage 1, 2 etc. I've read that some dry sump kits don't need an oil tank ?
Old Mar 18, 2014 | 11:24 AM
lacey's Avatar
lacey
A dry sump will have a remote storage of some sort ie a tank
A wet sump won't need a tank
You can run a external pressure pump
With wet sump .
Dry sump is normally the best and safest way to go
And if you send 5/10k on a engine you want it to last more than 5 minutes
If you decide to go dry sump then pm
Me
Old Mar 18, 2014 | 12:09 PM
s1cab's Avatar
s1cab
http://m.ebay.co.uk/itm/171034281483?nav=SEARCH this any good ?
robnock
21
May 13, 2019 05:29 PM
Gadget
Aug 26, 2015 01:02 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
