Which wide band lambda for ofam?
Old Mar 17, 2014 | 08:08 PM
wedge07's Avatar
wedge07
Default Which wide band lambda for ofam?
Spoke to rick at unicorn motor development and he said to get either innovate or Zeitronix. Which is the best to use with ofam ecu? Need get it ordered asap so I can get the car in for mapping. Cheers
Old Mar 17, 2014 | 08:19 PM
studabear's Avatar
studabear
I use a aem on mine, its been spot on, from www.efiparts.co.uk
Old Mar 17, 2014 | 08:23 PM
wedge07's Avatar
wedge07
Cheers mate I'm stuck which one to get. Are they all the Same?
Old Mar 17, 2014 | 08:29 PM
studabear's Avatar
studabear
I'm sure I've read that they all use the same sensors, but I only have experience of the aem.
Old Mar 17, 2014 | 08:33 PM
wedge07's Avatar
wedge07
I might get that ordered Tomoz then mate. Think I'm going to take it to get sorted by rick do need get it installed before hand
Old Mar 17, 2014 | 08:44 PM
studabear's Avatar
studabear
Yeah you will need it fitted before mapping, unless rick sticks a wideband up the tail pipe.
Old Mar 17, 2014 | 08:51 PM
wedge07's Avatar
wedge07
Yeah I'm gonna get it installed this week mate. Where does lambda go? Best place on exhaust I mean?
Old Mar 17, 2014 | 09:10 PM
studabear's Avatar
studabear
on my cvh I had it near the alternator, on my zetec turbo I've moved it to just infront of the driveshaft pointing upwards.
What front pipe have you got?
Old Mar 17, 2014 | 09:24 PM
studabear's Avatar
studabear
Old Mar 17, 2014 | 09:49 PM
wedge07's Avatar
wedge07
I'll put it about 6-8 inches below the elbow on the downpipe then mate . That'll be ok won't it?
Old Mar 17, 2014 | 10:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Either will fine, the ECU can use any WB02.
Old Mar 17, 2014 | 10:20 PM
wedge07's Avatar
wedge07
Ok sound cheers guys. I'll get it ordered Tomoz
Cosnada
Jan 7, 2016 05:30 PM
benw456
Sep 16, 2015 05:27 PM
Si B
Sep 12, 2015 06:49 AM
bigryrs
Sep 7, 2015 06:45 PM
