Modifying the ISCV for Antilag
Old Mar 16, 2014 | 02:09 PM
Sonic Boom's Avatar
Sonic Boom
Default Modifying the ISCV for Antilag
Who can modify my ISCV and throttle body for antilag?
I know MSD do it but probably only for their own systems, this is for an after market ECU setup.
Cheers Rich
Old Mar 16, 2014 | 07:33 PM
dissmalrs's Avatar
dissmalrs
hi mine is done by msd and its not been cut about at all
Old Mar 16, 2014 | 08:00 PM
Sonic Boom's Avatar
Sonic Boom
If it hasn't been modified then you must be running very mild antilag.
I need to run a reasonable aggressive setup.
Rich
Old Mar 16, 2014 | 08:07 PM
William MK2 Cosworth's Avatar
I bought a second hand throttle body and iscv for the anti lag , but in the end I just welded a take off on the manifold and plumbed in a external bypass valve. It runs the anti lag a lot better aswell
Old Mar 16, 2014 | 11:35 PM
markk's Avatar
markk
Don't bother modding the standard valve.
Find an alternative that bypasses lots more air if its for your competition car.
I used a Bosch Roller cell about 10 years or so ago as well as a standard valve, gave effectively 2 stages of ALS.
What ECU you running?
I don't have any idle bypass of ALS valves now at all, all done by active throttle control.
Old Mar 17, 2014 | 10:43 AM
Sonic Boom's Avatar
Sonic Boom
pm'd you mate.
Rich
Old Mar 18, 2014 | 10:18 AM
Sonic Boom's Avatar
Sonic Boom
Could I just use 12v solenoid rated to the correct flow and pressure?
Then just plumb it in either side of the throttle body?
Cheers Rich
Old Mar 18, 2014 | 12:13 PM
markk's Avatar
markk
PM sent.
Old Mar 18, 2014 | 04:00 PM
Rob Virgo's Avatar
Rob Virgo
Might be going different route now but I have a few ole anti lag is cvs if your stuck...
Old Mar 18, 2014 | 08:09 PM
Sonic Boom's Avatar
Sonic Boom
Standard ISCV modified for Antilag?
Or purpose made air by pass valves?
Cheers Rich
Old Mar 18, 2014 | 08:39 PM
Rob Virgo's Avatar
Rob Virgo
Std modified afaik
Old Mar 18, 2014 | 08:41 PM
Sonic Boom's Avatar
Sonic Boom
Std modified afaik
How much are you after for it?
Rich
Old Mar 18, 2014 | 09:12 PM
Rob Virgo's Avatar
Rob Virgo
Not sure it they work so cover post and there yours....
Old Mar 18, 2014 | 09:15 PM
Sonic Boom's Avatar
Sonic Boom
pm'd
Rich
DixieTheKid
11
Jun 6, 2020 11:20 AM
mk1turboestate
Dec 2, 2015 08:31 PM
DAZZER
Sep 30, 2015 08:43 PM
RSmark84
Sep 13, 2015 01:29 PM
cozzy jeff
Sep 12, 2015 04:32 PM
