Zetec Turbo Engine - Turbo Recommendations
Old Mar 16, 2014 | 01:38 AM
HaggisTurbo's Avatar
HaggisTurbo
Default Zetec Turbo Engine - Turbo Recommendations
Hi All, gave up on my CVH and decided to go down the Zetec Turbo route,
Bought the ST170 Bottom End and 2.0 Blacktop Head from Davysaff so going to crack on with that.
I currently have what I think is a standard T3 turbo that I dont think will be up to the task.
What turbo do you recommend and what exhaust housing size do you recommend etc.
Looking for as close to 300 hp as possible, ideally wanting to keep the standard RST exhaust manifold.
Whilst im at it can anyone explain what the whole .36 / .38 etc means as I am mega confused lol
Many thanks folks - Appreciate it
Old Mar 16, 2014 | 03:00 AM
mgtkr1's Avatar
mgtkr1
.36 is the housing size, .48 is larger. a stage 3 t3 which will have the .48 would be a decent turbo on a zetecturbo with good response
Old Mar 16, 2014 | 08:47 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
I'd use a T35 less lag than a T34 with .48 this will get the power you want.
Old Mar 16, 2014 | 08:51 AM
De4n0's Avatar
De4n0
I've got a garret t28 hybrid, standard focus rs t25 with t28 internals. Hoping for 300+ myself. And you can pick them up for reasonable price, turbo technics sell them and may even do you a deal with your turbo in exchange. I'll also be using a forge actuator with it.
Old Mar 16, 2014 | 08:56 AM
crazycage's Avatar
crazycage
Id go for a new manifold and a Evo 9 turbo
Old Mar 16, 2014 | 05:43 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If using an RST manifold then a stage 3 T3 will be very very punchy and just do 300bhp, could even go 60 trim comp wheel for a bit more flow as the Zetec will swallow it.
Old Mar 16, 2014 | 08:04 PM
Matt478's Avatar
Matt478
What sort of money can these be picked up for? I'm going to be needing a turbo soon. The manifold I have is off an RS and has the t25 flange on it.
Old Mar 17, 2014 | 02:58 PM
HaggisTurbo
Karlos what psi will be needed on a Stage 3 t3 to get 300? The one I am getting has a 360 degree rollerbearing and cut back blades with a .48 on it, would that be up to the task?
Old Mar 17, 2014 | 03:25 PM
De4n0's Avatar
De4n0
Depends if you want them new or not, turbo technics will be able to give you a quote but I was watching one on ebay that went for between 2-300 if I remember correctly.
Old Mar 17, 2014 | 03:37 PM
De4n0's Avatar
De4n0
These may be worth looking at,
http://www.ebay.co.uk/itm/Zetec-Turb...item3cde33c1f4
http://www.ebay.co.uk/itm/Garrett-GT...item3a8d218b7c
http://www.ebay.co.uk/itm/Turbo-Tech...item1e88673896
Old Mar 17, 2014 | 10:24 PM
Karlos G's Avatar
Karlos G
Balls Deep!
That's a very difficult question to answer as everything from your CR to what manifolds you use changes the boost level you will see for a desired BHP... it's about flow not pressure.
But very roughly 20-25psi, yes that should do it.
Old Mar 25, 2014 | 10:07 AM
HaggisTurbo
Thanks Karlos, I am ideally looking to keep the RST manifold as it's matched to the downpipe so is less hassle to change it, Is there any other turbo's that fit this Manifold? I take it a T34 / T35 would fit? Would the T34 and T35 need to be uprated in anyway?
Would they be recommended over a stage 3 t3 or is the stage 3 the best opton?
Old Mar 25, 2014 | 10:08 AM
HaggisTurbo
Ideally looking for a bit over 300 hp with IDEALLY some room for future growth so I am not running on it's limits. Although if a Stage 3 T3 is more cost effective I could settle for that,
Your thoughts
Thanks
Old Mar 25, 2014 | 05:18 PM
crazycage's Avatar
crazycage
T34.48 ,fits the rst manifold and good for upto about 370hp
Old Mar 25, 2014 | 06:32 PM
HaggisTurbo
So by that logic I take it that anything that begins with T3 should fit that bracket / Manifold?
Thanks
Old Mar 25, 2014 | 06:36 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah that would be a nice choice with some headroom too.
Thanks
Pretty much yes! lol But only an RST T3 will fit the RST down pipe AFAIK.
Old Mar 25, 2014 | 09:56 PM
HaggisTurbo
Karlos, Does that mean if I went T34 I would have to get a different Manifold / Downpipe anyway?
Old Mar 25, 2014 | 10:03 PM
Matt478's Avatar
Matt478
I've a focus RS tubular manifold with. T28 flange.
I've heard a GT28R is a popular choice.
Old Mar 26, 2014 | 05:00 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Manifold no, down pipe yes.
Old Mar 31, 2014 | 05:02 PM
HaggisTurbo
Have recently bought a 4x4 Saph Cosworth Turbo so 60 comp wheel etc. Is there an adaptor or elbow I can fit that will line up with a RST downpipe?
Also been offered a T35 at a good price (Big Turbo EsCos .63 Exhaust etc) what work would be involved in fitting this to a ZT using the RST manifold? Would space start to become an issue with the turbo being bigger and is it quite laggy?
Out of the two what would you recommend ad the best one to go for and without masses of work getting it to fit
Old Mar 31, 2014 | 05:36 PM
luke19790_3's Avatar
luke19790_3
I got a t34.55 on my zetec, space is a issue when using a different manifold
Old Mar 31, 2014 | 06:42 PM
HaggisTurbo
Hi mate do you suffer much lag with that setup? What manifold you using?
Old Mar 31, 2014 | 09:42 PM
luke19790_3
Don't know, haven't finished it yet
Old Apr 1, 2014 | 10:18 AM
HaggisTurbo
Haha that helps Luke, Any one else ?
Old Apr 1, 2014 | 10:23 PM
Karlos G's Avatar
Karlos G
Balls Deep!
.63 is too big unless you want 500bhp and lots of lag! lol
I would use the 4x4 T3 and fab a Cossie down pipe onto a RST exhaust.
Old Apr 2, 2014 | 05:56 AM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
You could get a rst .48 housing and put your t34 compressor and core onto it nice turbo you'd have there and you can use a standard down pipe
Old Apr 2, 2014 | 06:01 AM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
You could also use a 1.8 exhaust cam to reduce the lag !
I ran a .55 housing with a t34 front made a nice setup peak boost by 3000rpm
Old Apr 2, 2014 | 11:58 PM
HaggisTurbo
Hi mate, do you know where I would source one of these ? Had a long look online and cant find anything, a 4x4 adaptor to save me making a custom downpipe would also help lol
Old Apr 3, 2014 | 06:14 AM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
I no somebody who has a 0.63 rst exhaust housing but it would be a bit big for the response your after you best bet is to put a wanted posted on here or try eBay they do come up time to time
Old Apr 3, 2014 | 08:55 AM
Karlos G's Avatar
Karlos G
Balls Deep!
I think I might have one but I'm going away for two weeks Saturday morning so may not have time to look before then but I'll try.
Old Apr 3, 2014 | 10:19 AM
HaggisTurbo
Karlos,
That would be great mate if you could let me know!
Ill drop you a PM anyway
Old Apr 18, 2014 | 06:35 PM
HaggisTurbo
So decided to upgrade the turbo in the end to a T34 .48 housing, Is it safe to block the water feeds off on these or should I use them? What would I need to block them if I did do it?
Old Apr 22, 2014 | 07:34 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Fine to run a T series without water cooling, they don't need blocking off on the turbo (unless you just want to of course).
Old Apr 22, 2014 | 09:57 PM
HaggisTurbo
cool Karlos cheers, Hope you enjoyed the holiday
Old Apr 23, 2014 | 04:43 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I did mate thanks, it was great to have a couple of weeks away from my normal hectic life! lol
Chopshop85
Aug 17, 2015 06:38 PM
Bailes1992
Aug 16, 2015 07:14 PM
muz
Aug 16, 2015 12:57 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
Cameron
14
Aug 9, 2015 06:28 AM
