anyone on here using fixed or adjustable top mounts ?
Mar 10, 2014 | 05:45 PM
Anybody got any pic's of top mounts fitted ? Which makes are good etc I'm thinking of getting compbrake fixed top mounts
Mar 10, 2014 | 05:51 PM
Yep , got comp brake on both of mine
Mar 10, 2014 | 06:01 PM
whats the max camber on them
Mar 10, 2014 | 06:48 PM
Quote:
Originally Posted by
stuart collins
Do they go underneath the strut tops and then secure from above with 2 bolts ? Do you have any pic's mate ?
Mar 10, 2014 | 07:11 PM
Yeah, mine are the two bolt set up
Mar 10, 2014 | 07:13 PM
Cheers mate !
Mar 10, 2014 | 11:57 PM
i got the comp brake roller bearing jobbies too..... you can feel the difference
Mar 11, 2014 | 06:44 PM
always wondered about these too. Didn't know if it was ott or not..
Mar 11, 2014 | 07:52 PM
Which way round do the sleeve nuts go ? Ones longer than the other ?
Mar 11, 2014 | 10:15 PM
s1cab
To attatch the shock? Mine are both the same length.
Mar 12, 2014 | 08:09 AM
Mar 12, 2014 | 08:29 AM
I'll put a pic up later one is longer
Mar 12, 2014 | 03:19 PM
I would say the longer threaded sleeve would go at the bottom ?
Mar 12, 2014 | 03:20 PM
And i do away with the bush underneath the strut as it is atm ?
Mar 12, 2014 | 04:04 PM
The smaller bush goes underneath as a reducer spacer and the longer threaded insert goes through the top.
Mar 13, 2014 | 06:18 PM
I don't need the bushes anymore then ? so the coilover's will just be solid onto the top mount ? Just never had them before and want to be sure.
thanks
Mar 13, 2014 | 06:25 PM
Yeah, ditch the rubber completely.
Mar 13, 2014 | 06:47 PM
Cheers for that ! Will be fitting them this weekend. Just going to take my time on drilling the two holes through the strut top, make sure they are perfect before drilling
Mar 13, 2014 | 07:18 PM
as muz says ditch the rubber. when you take it out you will see the difference
Mar 19, 2014 | 07:28 PM
Is this the correct order to put these on ? I do keep the metal domed bit that sits on top of the spring don't I ?
Mar 20, 2014 | 08:04 AM
Yes, you retain the black alloy top hat and do away with EVERYTHING Ford inc that bearing you still have on the shock.
Mar 20, 2014 | 11:10 AM
I remove both of these then ?
Mar 20, 2014 | 07:42 PM
Mar 21, 2014 | 10:35 AM
Mar 21, 2014 | 12:09 PM
Thanks alot for your help mate much appreciated
jessie_rs
11
Jun 3, 2019 04:57 PM
James Porter
Oct 28, 2015 12:17 PM
yatta
Sep 1, 2015 11:28 AM
FlashRS
13
Aug 31, 2015 06:02 PM
dal3door
Aug 13, 2015 06:55 AM
