curently fitting master cylindrrs to my pedalbox
Old Mar 8, 2014 | 02:57 PM
s1cab's Avatar
s1cab
Default curently fitting master cylindrrs to my pedalbox
I have 2 new girling mastercylinders for my pedalbox, .70 and .625 am i right in thinking the .625 is for the front brakes? Using focus rs front brakes and cosworth 2wd rears.
Old Mar 8, 2014 | 03:03 PM
muz's Avatar
muz
Wye Valley Hardcore
Yes. Smaller cylinder for the larger brakes.
Old Mar 8, 2014 | 03:07 PM
s1cab's Avatar
s1cab
Cheers mate. How did you get on with the rear suspension on yours ?
Old Mar 8, 2014 | 03:45 PM
muz's Avatar
muz
Wye Valley Hardcore
It's a work in progress mate. Can't work on it this weekend. My threads as far as I've got., so far. I'm looking at re-designing my pedal box as well. Are you still using the Compbrake like mine or something different?
Old Mar 8, 2014 | 04:19 PM
s1cab's Avatar
s1cab
The compbrake one but i went for girling master cylinders. It's on my table as I write this lol. I'm just putting it together. I'm not to keen on the bit that goes through the centre which attatches to both the master cylinders with the bar. The fact that it only has one bearing in the part that pivots doesn't seem that great. When i push the rod by hand it's going on the piss abit, but i can see that both master cylinders are working. Just thought if it had two bearings the bar would be alot more stable and push both cylinders evenly
Old Mar 8, 2014 | 04:22 PM
gus's Avatar
gus
do you mean the bar is biased to one side?
if so its supposed to be
will give bias to front or back
Old Mar 8, 2014 | 04:29 PM
s1cab's Avatar
s1cab
Yeah i suppose its pushing the front cylinder more so that's normal yeah ?
Old Mar 8, 2014 | 05:01 PM
gus's Avatar
gus
thats it mate
so front brakes will brake harder than rears
Old Mar 8, 2014 | 05:17 PM
s1cab's Avatar
s1cab
thats it mate
Cool thanks for clearing that up
original
Apr 28, 2026 05:20 PM
moesin2005
Jan 23, 2022 06:28 PM
frug
Aug 26, 2015 06:46 PM
Caddyshack
Aug 19, 2015 07:29 PM
