Ford Range This section is for other models in the Ford range.
Granada scorpio fault
Old Mar 4, 2014 | 11:16 AM
vinny.jones's Avatar
vinny.jones
Default Granada scorpio fault
Can anyone please help with ideas to what our problem is with a 1988 Granada 2.9 injection scorpio , We have bought the car and when driving every now and then it goes as if its starved of fuel for few seconds or so then judders but then picks back up on its own , Or if when it does this i put foot my down more it clears and goes back to normal but it keeps happening all the time . Even when start off it does it and then starts to judder but soon as i stick my foot down and give it more it goes but then comes back just as quick if i slow up etc or just cruise at any speed but if i dont put my foot down to overcome it then it will judder like hell. Ive Changed throttle position sensor off another car plus its had new fuel filter and changed the fuel pressure regulator and its also had new set of plug leads plus coil . Ive also Tried looking and unplugging all conections i can find then plugging them back plus took fuses all out checked and cleaned and there is no cat so its not that either, Also took dash all out to get at fuel relays etc under dash top and swapped them around and so on but still same , got new fuel pump on order so will also try that once it arrives . Anyone had same problem or got Any idea please ?
Old Mar 4, 2014 | 11:20 AM
Colin_P's Avatar
Colin_P
I had one of these in the late 90's
Have you checked the resistance on the air mass / flow meters, there are two.
Old Mar 4, 2014 | 11:26 AM
vinny.jones
no sorry ive no idea how do i do that
Old Mar 4, 2014 | 12:19 PM
dojj's Avatar
dojj
Resident Wrestling Legend
remove the air flow meters (passenger side behind the headlight)
you will see that they have flaps in them to measure the air flow
push the flaps with a finger and see if there is any resistance when you push them or when they return back to their stops
this is a very common fault and i'm pretty sure that if you were to look out the rear window you'd see a puff of black smoke as it's then running rich
Old Mar 4, 2014 | 12:20 PM
dojj's Avatar
dojj
so you unclip the air filter cover, then the 2 multiplugs (they are wired differently so you should rememeber which one goes where) and then undo the 2 big jubilee clips and its out
Old Mar 4, 2014 | 04:10 PM
vinny.jones
what would i do then clean them or replace ?
Old Mar 4, 2014 | 05:12 PM
Colin_P's Avatar
Colin_P
Ideally you would need to measure the resistance in ohms as you move the flap through from closed to open.
As there are two it should be easy to work out which one is duff. Of course they both might be knackered or both might be ok. A difference between the two will show one is duff but which one I don't know.
Someone might know what the specification (resistance) is for these.
Also, shamless plug here but I'm flogging these ...
Old Mar 4, 2014 | 08:37 PM
dojj's Avatar
dojj
they would need replacing as you can't really fix them
Old Mar 4, 2014 | 08:51 PM
vinny.jones
Take a look at ebay item 261412998983 is that the things your saying about ? I was going to upload a pictures but im new here and dont know how sorry . Anyway there are 2 of these on the granada like you say passengers side however i have another granada just a few years newer and same engine etc yet it dont have these on it
Old Mar 5, 2014 | 04:27 PM
dojj's Avatar
dojj
one has catalytic converters and the older ones doesn't
they use a different measuring system for the air pressure but i cna't rememeber off the top of my head what that would be called, it my be a map sensors or the like or hot wire sensor or something
simples
Old Mar 5, 2014 | 04:29 PM
dojj's Avatar
dojj
that's a lot of money for 1 afm, plus it's from the 2.8 which may not make it suitable for the 2.9 application
i know the 2.0 pinto ones don't fit either
Old Mar 5, 2014 | 05:40 PM
vinny.jones
yeah see what your saying but it looks same as the ones on mine and mine is the none cat , had new fuel pump today and still no joy its still same
Old Mar 5, 2014 | 08:15 PM
dojj's Avatar
dojj
ask this guy
http://www.ebay.co.uk/itm/FORD-SIERR...item3a8b2fd3a1
Old Mar 5, 2014 | 08:16 PM
dojj's Avatar
dojj
where as this
http://www.ebay.co.uk/itm/Ford-Grana...item3a8ca2474c
is the cat engine, as can be seen by the inlet pipes being different
Old Mar 5, 2014 | 08:18 PM
GVK.'s Avatar
GVK.
I preferred the Rover P6 you had in Lock Stock.
Old Mar 5, 2014 | 08:20 PM
dojj's Avatar
dojj
and here's another one
http://www.ebay.co.uk/itm/FORD-SIERR...item3a8b3ce0a9
Old Mar 5, 2014 | 08:29 PM
vinny.jones
yes the first 1 you show there are the same as mine and the others are the same as the other granada i have
Old Mar 6, 2014 | 04:36 PM
vinny.jones
new fuel pump now fitted to rule that out and its still the same
Old Mar 6, 2014 | 05:16 PM
GVK.'s Avatar
GVK.
Any air leaks on the intake? intake rubber piping from air flow meters to throttle body, inlet manifold gaskets/valley gaskets.
Is it just a HT misfire? spark plugs/leads/cap/rotor..
Old Mar 6, 2014 | 05:38 PM
vinny.jones
Hi GVK like your comment on the rover lol and i did have 3 of them , The scorpio as now had a throttle position sensor , fuel filter , fuel pressure regulator , fuel pump , plugs , leads , cap , coil , cleaned everything else i can think of and ive checked pipes but cant seem to find anything . Im now thinking do i strip inlet manifold etc and put new gasket to rules things like that out or would it be those air box meters even though them seem ok or will it be a injector . Im just getting nowhere and starting to run out of things to try
Old Mar 6, 2014 | 05:40 PM
vinny.jones
just dont understand that its fine and problem goes if give more throttle but once easy back off it comes back
Old Mar 6, 2014 | 06:08 PM
GVK.'s Avatar
GVK.
How does it idle, smooth or 'hunts' ?? if the idle is poor it may point to an intake gasket fault, it's years since I worked on the old V6s but did replace a few of the intake manifold and the 'valley' gaskets back in the day. Should be able to spray some WD40 or similar around the intake manifold flanges and see if engine note changes.
On more modern stuff you can disconnect the air flow meters so it just runs on TPS settings to prove a bad air-flow meter, not sure if the older ECUs support that..worth a try to rule it out, if it's even more terrible then we know..
Old Mar 6, 2014 | 06:12 PM
vinny.jones
it idles great no problem at all
Old Mar 6, 2014 | 06:59 PM
vinny.jones
If i disconnect the air flow meters 1 at a time the engine note does change or idle lowers etc and if i disconnect both the engine cuts out and wont run
Old Mar 6, 2014 | 08:32 PM
GVK.'s Avatar
GVK.
That answers that then..
What happens if you disconnect the TPS, does it still run?
Old Mar 6, 2014 | 08:46 PM
vinny.jones
tps being the throttle position sensor ? I cant remember now until i try again but yes i think it did still run will try it again tomorrow to see
Old Mar 6, 2014 | 09:43 PM
GVK.'s Avatar
GVK.
Yes TPS throttle position sensor.
Must be some proper tests you can do on the AFMs..
I will look..
Old Mar 10, 2014 | 06:41 PM
vinny.jones
disconnected the TPS and it will still start and run , also done full compression test and good on all 6
Old Mar 18, 2014 | 01:55 PM
vinny.jones
Well ive gone full out so the granada has now had Brand New plugs, New leads, New dizzy cap, New coil, New fuel filter, New fuel pump plus ive swapped things like fuel pressure regulator , fuel relay, and things like throttle sensor etc and still doing the same. Ive got old code reader now so will try look at it tomorrow and see if it comes up with anything
Old Mar 18, 2014 | 08:45 PM
dojj's Avatar
dojj
But youve still not changed the air flow meters which is the cause of the problem?
Old Mar 19, 2014 | 02:58 PM
vinny.jones
Well I'm now more stumped than ever because I've now got a code reader for the granada but I've tried tests and its coming up with nothing , I've even done a wiggly test and nothing plus its not air flow meters as I've also ruled them out because no codes come up however if I unplug a air meter or anything then it shows a code saying problem with them etc so I really don't know now what else I can do
Old Mar 19, 2014 | 03:17 PM
dojj's Avatar
dojj
the granada won't have any fault codes readable by the vast majority of fault code readers
you plug a light into the 3 pin diagnostic plug by the battery and it'll flash some sequence of lights to give you very basic info
and it won't be on the afm's as they won't read as a fault
remove the afm's and do the poke test i told you about earlier in the thread and change the one that sticks
there's a guy on facebook who's selling some afm's now that i can post up for you, but i'm not sure if i can post up stuff for sale from other folks so you'd have to get a mod to see if that was possible without me getting into trouble
Old Mar 19, 2014 | 05:19 PM
vinny.jones
Yes dojj its a Gunson's fault finder that does plug into the 3 pin diagnostic plug by the battery and ive got a book / instructions with it and the codes relating to the number of flashes etc and it does cover all things like the air flow meters etc and the flash code for afm is like 22 but its only giving me for code 11 and that means no fault - system pass . However if i slightly discont the afm or fully disconnect 1 cable it does throw the fault up saying afm so this to me shows the code reader is working fine and that the afm must be ok ? Also the links you did put up with fella on ebay i did message him and he wont sell the air flow meters and said he wants to sell them complete with the engine
Old Mar 19, 2014 | 07:51 PM
dojj's Avatar
dojj
ok, that's fair enough then
but i would warn you to stop spending money on stuff you don't need until you've changed the afm's first
if the fault remains after that then try something else
good luck and keep us posted with the updates
Old Mar 19, 2014 | 08:06 PM
GVK.'s Avatar
GVK.
All that code 22 is saying is that the AFM circuit is connected.
The fault still could be the AFMs as dojj has been saying.
Old Mar 20, 2014 | 12:35 PM
vinny.jones
Ok fair enough i understand what your saying however where could i get a set of afm that i know are guaranteed to be working ? The ones you put link for he wont sell them without the engine but even if found a set on say ebay then how do i know they are not naft just like mine and then we back to square 1 thinking it must be something else
Old Mar 25, 2014 | 12:43 AM
vinny.jones
Air flow meters bought and im waiting on delivery now to try them and see
Old Mar 27, 2014 | 12:31 PM
vinny.jones
Problem now sorted , I bought and fitted air flow meters but problem was still there so a mate then got hold of injection system with injectors off a Scrap car that was known to be working perfect so i changed that and injectors and all is spot on and driving great so i can only now think that the fault must have been injector braking down or blocking or something .
Old Mar 27, 2014 | 03:11 PM
dojj's Avatar
dojj
glad you've got it sorted
Old Feb 21, 2021 | 08:38 PM
johneisen2001's Avatar
johneisen2001
Default Ford Scorpio 2.9 12v
Hi, I have just come across this old thread interesting about injectors. Over time my car has been running bad, idle all over the place and running rich. I have just had my injectors cleaned I put them back in the car but it will not start. It turns over. I guess these are 24yrs old now. Should I just replace them for new injectors?
Gregr68
Ford Focus Diesel
Feb 3, 2017 09:36 AM
badj
Aug 13, 2011 09:09 PM
Belfast71
May 1, 2009 07:45 PM
s12045
Apr 1, 2009 03:00 PM
D7AKE
Escort MK 5 / MK 6
Jan 17, 2004 05:00 PM
