Mk1 rs stalling problem
Old Mar 2, 2014 | 10:16 PM
James_D's Avatar
James_D
Default Mk1 rs stalling problem
I noticed a while ago when driving. If you are coming to a stop and hold the clutch down while braking the revs would fall as normal but the fall below the idle point for a split second them rise back to the idle point. When it drops below the battery light comes on and then goes back off once it's ideling correctly again.
It doesn't do this all the time just now and then. Wasn't really a big problem but the other day when it done this it actually stalled the engine. It's started first time straight after but was just a little concerned.
I've done a search on here and noticed a few people have had the same problem but no one seems to have mentions a solution for it yet.
I'll probably just the get idle control valve replaced first to see if it makes a difference but people with the same problem have already done this and it hasn't solved their problem.
Old Mar 2, 2014 | 10:18 PM
dodge8283's Avatar
dodge8283
What dump valve is fitted to it? if its atmospheric this is your problem.
Old Mar 2, 2014 | 10:21 PM
James_D's Avatar
James_D
Car is standard apart from a decat.
Do you think it might be worth changing the DV pipes with silicon replacements?
Old Mar 2, 2014 | 10:31 PM
dodge8283's Avatar
dodge8283
If you look at the inlet manifold, underneath the throttle body the will be a breather pipe, check this for splits or if its even still on.
Old Mar 2, 2014 | 10:33 PM
James_D's Avatar
James_D
Thanks for the help
Its a bit dark now. I'll check tomorrow.
Anything else I should be looking for?
Old Mar 2, 2014 | 10:36 PM
dodge8283's Avatar
dodge8283
Id check any breather pipes bud, ones that go to the dump valve and ones at the back of the inlet. Also check the dump valve itself, it could be sticking.
Old Mar 2, 2014 | 10:42 PM
James_D's Avatar
James_D
Thanks mate, I'll update this tomorrow and let you know how I get on
Old Mar 3, 2014 | 12:01 PM
James_D's Avatar
James_D
So had a look today and couldn't find anything obvious. Well obvious to me anyway. I have found another problem though
Where the down pipe connects to the turbo I can feel a lot of air escaping. To me it looks like it's cracked all the way around the weld. So I took some pictures to see if you lot can confirm this or correct me.
Old Mar 7, 2014 | 11:39 PM
lowman's Avatar
lowman
well...u dont have to be a rocket scientist to understand that it is cracked...?and all the way round it seems.
Old Apr 25, 2014 | 10:16 PM
IanC's Avatar
IanC
I had similar problems on mine mine was the main battery earth to the body was corroded and loose also they never run well on less than quarter of a tank and that cracked decat won't help either get a bcs one on there top bit of kit
Old Apr 26, 2014 | 10:34 AM
anthony lea's Avatar
anthony lea
Ford allegiance
I have found one of the pipes to be split under the inlet manifold. Is this a ford only part or is there an alternative from the motor factors for instance?
Old Apr 26, 2014 | 11:54 AM
fiesta23's Avatar
fiesta23
Graham at car parts express sells the inlet pipes
Old Apr 26, 2014 | 02:14 PM
anthony lea
Ford allegiance
Car parts express? Where's that mate?
Old Apr 26, 2014 | 03:26 PM
fiesta23's Avatar
fiesta23
Search on google, he has a website
Old Apr 26, 2014 | 10:37 PM
IanC's Avatar
IanC
Roose sell them pal
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
jay030787
Sep 18, 2015 04:38 PM
Rammer46
Sep 18, 2015 08:31 AM
Flateric_2002
Sep 15, 2015 08:41 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
