what size backing plates for kestrel das 6?
Feb 19, 2014 | 12:48 PM
just ordered myself a kestrel das 6 pro which comes with 125mm and 150mm backing plates.
but i just wanted to know what other size i should get?
should i get a 75mm or a 100mm? or both?
whats your thoughts?
Feb 23, 2014 | 08:57 PM
Where did you get it and what package did you get? I'm looking at these at the minute, any links?
Feb 23, 2014 | 09:15 PM
I got a 3" (75mm) for the twiddly bits around badges etc and it's great. Get a flexi one as it's kinder on the paintwork.
Feb 24, 2014 | 12:02 PM
Quote:
Originally Posted by
Dal_
thats what im going to do! that size backing plate and a 3" pad is pretty cheap!
neilmanfocus1
http://www.cleanyourcar.co.uk/polish.../prod_673.html
this is the cheapest place to get a das 6 pro!
using this discount code gets you Ł15 off aswell! DAS6GROUPBUY
i went for the pro as after doing a bit of research people were saying its better to pay a little more and get the pro over the standard das 6 as it has a more powerful motor and makes getting rid of swirls and scratches easier! and it has a much longer cable!
Feb 24, 2014 | 12:23 PM
Ideal, how do you go out choosing pads etc, there are so many different opinions that's it gets a bit mind boggling!!?
lee2cossies
Aug 26, 2015 10:04 PM
borboyous
Aug 22, 2015 11:17 AM
Neatrags
Aug 16, 2015 07:57 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
