splutter and backfire
Old Feb 18, 2014 | 06:16 PM
lukewhite's Avatar
lukewhite
Default splutter and backfire
hi its me again I have finally changed the spark plugs,coilpack and fuel filter on my rs mk1 as I had replys saying change them it didn't do it briefly after but now its just started again any more suggestions on what it could be ?
thanks luke
Old Feb 18, 2014 | 06:35 PM
Osborne0121's Avatar
Osborne0121
Would a crank sensor damaged wire cause these symptoms maybe ???
Old Feb 18, 2014 | 07:48 PM
rallycross's Avatar
rallycross
What plugs have you used ?
Old Feb 18, 2014 | 08:09 PM
lukewhite's Avatar
lukewhite
i have used ford recomenned plugs they are iridum tip ones i think
Old Feb 19, 2014 | 08:37 AM
minder's Avatar
minder
what power you running ? and did you change the HT leads?
Old Feb 19, 2014 | 06:03 PM
lukewhite's Avatar
lukewhite
not a clue power wise maybe anywhere between 280-300bhp. And no didn't change the leafs but will do tonight
Old Feb 20, 2014 | 05:50 PM
minder's Avatar
minder
if you aint got a clue power wise what makes you think your running 280-300??
Old Feb 20, 2014 | 06:00 PM
lukewhite's Avatar
lukewhite
because it has been dynod at 300before and i have turned boost down a little due to thinkin it was overboosting. So now i don't know what it could be
Old Feb 20, 2014 | 06:19 PM
minder's Avatar
minder
if your running about that much power i would change the plugs again to what i told you to use as standard ones don't like anything above the normal 212 and use high performance
HT leads i am running 350 and no problems
Old Feb 20, 2014 | 06:21 PM
lukewhite's Avatar
lukewhite
i have just literally changed the leads to factory ones from magnacor ones and factory plugs. And it seems ok for now just been on a little run. I will go back high performance parts if it does it again. Thanks again anyway
Old Feb 20, 2014 | 06:26 PM
minder's Avatar
minder
glad you got it sorted mate
Old Feb 20, 2014 | 06:27 PM
lukewhite's Avatar
lukewhite
the leads and coilpack and little close to the intercooler pipe and gets very and and split one of the leads so kept arking out. So i had to put a bit of rubber inbetween
timsrs
Nov 13, 2018 11:48 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
tib2220
Sep 14, 2015 12:33 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
