MK1 Focus RS Standard Boost Gauge? HELP!
Old Feb 17, 2014 | 07:41 PM
De4n0's Avatar
De4n0
Default MK1 Focus RS Standard Boost Gauge? HELP!
I have purchased some rs clocks for my mk1 focus, I'll be fitting a zetec turbo engine and would like the boost gauge on the clocks to work, does anyone know how I would go about this? Thanks, dean.
Bottom left
Old Feb 18, 2014 | 03:54 PM
De4n0's Avatar
De4n0
Anyone? I'm assuming I'd need the standard focus rs boost solinoid that attaches to the turbo and actuator but I've read that this solinoid isn't that good and most people remove it but is there a way of either removing it or upgrading it so the boost gauge still works if this is what controls the gauge that it, thanks.
Old Feb 18, 2014 | 03:59 PM
adsrs1's Avatar
adsrs1
I wouldn't bother mate it's not accurate you are better off with a aftermarket one
Old Feb 18, 2014 | 04:02 PM
De4n0's Avatar
De4n0
I see, if I do get an after market one is there a way of doing this still with the rs one working, even though it's not too accurate, I hate the idea of of something not working and just being wasted space
And can you recommend a good one?
Old Feb 18, 2014 | 04:08 PM
adsrs1's Avatar
adsrs1
This is the one I have
I have know idea how you could wire it in unless you have the wiring harness and can splice it to get a reading from some where
Old Feb 18, 2014 | 04:10 PM
De4n0's Avatar
De4n0
Ah looks kwl, does that wire straight into your plug at the back of you clocks?
Old Feb 18, 2014 | 04:14 PM
adsrs1's Avatar
adsrs1
It takes the live from the back of the radio
Old Feb 18, 2014 | 04:16 PM
De4n0's Avatar
De4n0
Any idea were it gets the information for the boost?, cheers
Old Feb 18, 2014 | 04:17 PM
adsrs1's Avatar
adsrs1
On the focus rs you plumb it Into the pipe before the canister
Old Feb 18, 2014 | 04:23 PM
De4n0's Avatar
De4n0
Youll have to bare with me mate this is a little new to me, what canister would that be? So that gauge doesn't run with wires but with pipes? Im now thinking that it is the standard boost solenoid is what makes the standard gauge work, thanks for your help mate,
Old Feb 18, 2014 | 06:17 PM
adsrs1's Avatar
adsrs1
The canister is the black cylinder behind the power steering bottle
Old Feb 18, 2014 | 06:19 PM
De4n0's Avatar
De4n0
Ahh i see, thanks for that mate
Old Feb 18, 2014 | 06:26 PM
adsrs1's Avatar
adsrs1
You pull the pipe off to the right of the canister and fit the tee that comes with the boost gauge and the pipe from the gauge then connects to the tee giving you a working gauge
Old Feb 18, 2014 | 06:29 PM
De4n0's Avatar
De4n0
Is that canister something thats fitted to all focus's or something im going to have to get? Sure ive seen something like that under my bay before .
Old Feb 18, 2014 | 06:30 PM
adsrs1's Avatar
adsrs1
I think that's fitted just to the rs may be wrong
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
track.focus'd
Aug 12, 2015 05:53 PM
no1trancefan
Ford Focus ST
Aug 7, 2015 09:21 PM
