Is my car an old press release ???
Old Feb 13, 2014 | 08:02 PM
Mossy XR2 Turbo's Avatar
Mossy XR2 Turbo
Default Is my car an old press release ???
hi all, i had some pics of my 3i on facbook and someone commented saying the last 2 letters are the same as alot of old press release cars, is there anyway of finding out if it was or not, thanks for any help
Old Feb 13, 2014 | 10:20 PM
GVK.'s Avatar
GVK.
Mostly an urban myth, I'm guessing it will be a car registered in Chelmsford area.
Ford press/staff cars were registered in that area also old Ford rally cars when Boreham was on the go, there's a thread on here with the reg's listed.
Unless you can find out the real history, it's more than likely just a car registered in that area.
Old Feb 13, 2014 | 10:22 PM
GVK.'s Avatar
GVK.
Found an old post.
Originally Posted by fiestaturbo1984
Weren't registrations that end in HAR something along the lines of press car's or something like that?
Just means they're first registered in Chelmsford,Essex.
Not necessarily Ford owned..
I just found a post from last year
Originally Posted by GVK
Under the previous system, the registration plate usually contains a group of two or three letters (if three, ignore the first, and use the second & third); very old ones use only one letter; these indicate the place of first registration. Some of the ones marked ‘unused’, and some special combinations, e.g. N 1 GEL, were issued centrally as vanity plates by the Driver and Vehicle Licensing Agency). Originally the letter group was placed first, followed by the number group, but from 1952, this order began to be reversed.
AR - Chelmsford
EV - Chelmsford
JN - Chelmsford
HJ - Chelmsford
HK - Chelmsford
NO - Chelmsford
OO - Chelmsford
PU - Chelmsford
TW - Chelmsford
VW - Chelmsford
VX - Chelmsford
If you look at a lot of (pre 2001) Ford press cars and Boreham built rally cars, they will probably have one of the above reg plates.
Full list here - http://www.kingkong.demon.co.uk/where/gb.htm
Old Feb 13, 2014 | 10:32 PM
GVK.'s Avatar
GVK.
If it's the grey cab on your sig link...
JX - Huddersfield
Old Feb 15, 2014 | 12:17 PM
Smit's Avatar
Smit
The 60ft Launch King
JX - Huddersfield
No it's not. The car is question is a Red 88 xr3i which he has 'aquired'
Old Feb 15, 2014 | 12:23 PM
GVK.'s Avatar
GVK.
I did say if as it wasn't stated what car he was asking about.
Shows & Track Days
Aug 26, 2015 05:11 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
druidgetafix
Aug 15, 2015 10:22 AM
