Hydraulic conv T5 bell housing question
Old Feb 12, 2014 | 06:39 PM
BRAMMER's Avatar
BRAMMER
Default Hydraulic conv T5 bell housing question
Mines away at the fabricators but i want to double check before they carry on with the work
Is their any clearance issues with the tunnel, I've seen some mill in to the housing for the rod to pass though but when i measured it all up it didn't appear to need it which made me think was their a clearance issue?
Pics if you have please
Old Feb 12, 2014 | 07:08 PM
fraser9764's Avatar
fraser9764
Ive not put mine in the tunnel yet, but I fitted my slave as close to the box as possible, which meant the rod pretty much touched the bellhousing, so I just filed a few mm out to make sure it didnt touch. I figured if it didnt fit in the tunnel then I would make it fit with the aid of a lump hammer....
Old Feb 12, 2014 | 07:10 PM
fraser9764's Avatar
fraser9764
Old Feb 12, 2014 | 07:55 PM
BigErn's Avatar
BigErn
I need to do the box end of mine now. Im gonna adopt the same method as above..... nice and tight to the box and if it dont fit Ill make it fit with a bit of tunnel reshaping
Old Feb 12, 2014 | 08:49 PM
BRAMMER's Avatar
BRAMMER
I bought my kit with the fitting in the clutch arm already so they are going to dummy up and see where the slave goes then mount the extra metal to suit but my kit came out of an escos with T5 but don't know if their is any difference at all between tunnel, I know they were based on Sierra floor but you never know
Old Feb 12, 2014 | 09:03 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
No issues with my Reyland conversion Chris.
Steve
Old Feb 12, 2014 | 10:10 PM
BRAMMER's Avatar
BRAMMER
Steve
The kit i have is Reyland but i didn't get the bell housing, but i'm sure once its all mocked up it will be fine
This is my box which once the slave is rested on touches the gearbox part so i'm not sure what benefit milling into to the housing would achieve
Old Feb 12, 2014 | 10:49 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
I had the reyland conversion on my old 3dr, but it wasnt a cosworth shell just a gl.
So not sure of any size difference but i did have to persuade the tunnel with a lump hammer!
Old Feb 13, 2014 | 12:12 AM
lee2cossies's Avatar
lee2cossies
Why not use the centre push hydraulic clutch conversion? Isn't this better?
Old Feb 13, 2014 | 06:28 AM
fraser9764's Avatar
fraser9764
I don't like center push kits as the bearings don't seem to cope with the high pressure plates. I would rather sacrifice looks and maybe some smooth/lightness, to not have to take the box out if there is a problem.
Old Feb 13, 2014 | 12:36 PM
BRAMMER's Avatar
BRAMMER
Useless plus the external way is easy just making sure it's not going to have clearance issues
Old Feb 13, 2014 | 01:17 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Centre push kits are shit I no some one who has gone through 5 bearings with his ap clutch! There not made for heavy clutch covers as there standard bearings taken from other cars and adapted. I'm going to order a rayland kit for mine nearer the summer when I get really cracking on mine
Old Feb 13, 2014 | 01:27 PM
nixon_2wd's Avatar
nixon_2wd
Ive had this one in combo with 750Nm AP twin plate clutch for a couple of years now. No problems yet.
http://www.apracing.com/product_deta...59_family.aspx
Got to use real quality parts, not cheap shit parts from china.
Old Feb 13, 2014 | 01:29 PM
ajamesc's Avatar
ajamesc
One I know of is in a green wide arch mk2 with a yb it uses a saab bearing.
Old Feb 13, 2014 | 03:18 PM
James @ M Developments.'s Avatar
You maen your going to dig around in the tool box for your biggest hammer and....
I cant help but sing this song when im doing stuff like that
Old Feb 13, 2014 | 06:05 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
You will have tunnel clearance issues if you don't machine the belhousing, plus you're effectively altering the leverage by running the cyl further out.
Old Feb 13, 2014 | 06:08 PM
Martin-Hadland
My 500 runs a heavy cover with my centre push and as most people probably know I do some serious miles in my car when I use it, amount of problems.... Zero
chowfornow
14
Jan 5, 2019 09:01 PM
tankybaby66
Feb 6, 2016 02:24 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
