Crushed jacking points (Cosworth)
Old Feb 10, 2014 | 01:45 PM
Cossy Mike's Avatar
Cossy Mike
Default Crushed jacking points (Cosworth)
Anyone have any tips on how to repair or replace?
I can't seem to find much that looks any good
thanks on advance
Old Feb 10, 2014 | 04:35 PM
tosh's Avatar
tosh
I 're-shaped mine by beating them out from Inside the footwells, only because I needed to cut out above them any way because of rotten footwells, but I suppose you could use a slide Hammer and do it from the outside!
Old Feb 10, 2014 | 05:01 PM
Cossy Mike's Avatar
Cossy Mike
I was hoping to avoid that......
I'm wondering if anyone does repair panels or if I could fabricate a couple somehow, or chop them off another car and weld them on?
Old Feb 10, 2014 | 05:23 PM
whizzisat114's Avatar
whizzisat114
I made some for a 3dr years ago when i did an underside resto on it
Pretty easy shape to make and with them welded in the corners i covered the welds up with the sealer
Old Feb 10, 2014 | 06:09 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
I chopped mine off reshaped them and welded them back on
Before
After
Old Feb 10, 2014 | 06:19 PM
costina's Avatar
costina
Live long and prosper!!
Mike I done my mates ones welded studs on and used a slide hammer. welded any holes made by pulling.
regards
Paul
Old Feb 10, 2014 | 08:27 PM
Cossy Mike's Avatar
Cossy Mike
Thanks for all the replies!
Looks like I have some options then
I'm liking the idea of chopping them off and re shaping them and welding them back on
Old Feb 11, 2014 | 05:27 AM
They do look neater.
dojj
Aug 25, 2015 06:56 PM
TrevCos
Aug 22, 2015 06:05 PM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
