omex 600
Old Feb 6, 2014 | 08:50 PM
s1cab's Avatar
s1cab
Default omex 600
Going to be sorting out the wiring on my escort zetec turbo over the next few weeks. Had a quick look earlier and found a lambda sensor that goes back to the ecu.. Is this needed ? It's just i've already got a wideband lambda sensor in the exhaust that goes to my afr guage, just wanted to know if I need to get another lambda boss welded into the exhaust or not ?
Old Feb 6, 2014 | 09:27 PM
stevieturbo's Avatar
stevieturbo
C**t
Omex will be able to take the voltage output from your wideband controller and use it.
There would be no real reason to install a narrowband
Old Feb 7, 2014 | 09:10 AM
s1cab's Avatar
s1cab
Ok thanks
IainRS1700T
Sep 25, 2015 06:44 AM
dombanks
Sep 21, 2015 08:38 PM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
Tank Mike
Sep 14, 2015 03:56 PM
