Abs Ecu tech questions
Old Feb 5, 2014 | 08:45 PM
RSLUBBY's Avatar
RSLUBBY
Default Abs Ecu tech questions
Having problems with my abs ongoing for a year now etc.
Only left to check is the Ecu need to borrow one
Are saff 4be 4 same?
Are Sierra xr4be same?
Wiring checked speed sensors checked abs rings checked everything reading correct!
Any help would be appreciated
Cheers ian
Old Feb 21, 2014 | 01:03 PM
opposite lock's Avatar
opposite lock
If its the Sierra/Granada system try here
https://passionford.com/forum/techni...agnostics.html
Old Feb 21, 2014 | 01:49 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the 2wd ones are the same (other than the 3 door cossie) and the 4wd ones are the same as well
across the range from memory as they will have either a green or a red plug on the loom side and have a sticker telling you it's 4wd on the ecu itself
not sure where you are but i've got a few spare ones kicking about i could look for if you are stuck
Old Feb 22, 2014 | 05:26 PM
dojj's Avatar
dojj
Old Feb 22, 2014 | 05:31 PM
grcossie's Avatar
grcossie
Are you sure that escos have the same as Sierra? Escos have a g-sensor who Sierra dosen`t have
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
IainRS1700T
Sep 25, 2015 06:44 AM
liamT74
Sep 23, 2015 10:24 PM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
