msd distributor blank help
Old Feb 2, 2014 | 11:12 PM
lime's Avatar
lime
Default msd distributor blank help
quick question i bought the distributor black from msd , with regards to the distributor rotor shaft and gear should i remove those as well
Old Feb 2, 2014 | 11:17 PM
dazzle740's Avatar
dazzle740
No mate as the shaft will still be needed as your phase sensor will still be in use(unless mounted to rocker cover to pick up on cam) just remove the HT leads and the distributor cap and fit the blank.
I assume you also have the rest of the wasted spark kit too.
Old Feb 2, 2014 | 11:18 PM
lime's Avatar
lime
yes i have all the bits
Old Feb 2, 2014 | 11:21 PM
lime's Avatar
lime
i have a another question i went to modify the back of my tach it seems i have one the rear type ones so i was wondering how easy would it be to fit a aftermarket one what would need to be done
Old Feb 3, 2014 | 12:46 PM
martysmartie's Avatar
martysmartie
Do not remove it!
As said you need to relocate the phase sensor to the cam cover, but more importantly you need machining work done, as when you remove the dizzy it also will stop the drive to the oil pump!
Martin
Old Feb 3, 2014 | 01:18 PM
lime's Avatar
lime
Ok how do I relocate it to the cover
JK12
33
Apr 26, 2021 12:09 PM
TPM961
Jan 15, 2018 10:50 AM
20/20 vision
Sep 29, 2015 11:27 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
