Question - Standard Cosworth Exhaust Cam
Old Feb 2, 2014 | 11:26 AM
delbee1's Avatar
delbee1
Default Question - Standard Cosworth Exhaust Cam
I know you can use the standard exhaust cam up to around 500bhp
My question is are you guys running a proper standard cam or a Kent or similar BD8??
The reason I ask is that I have a kent inlet cam and its loads thicker than the standard exhaust cam...
Answers much appreciated
Old Feb 2, 2014 | 03:07 PM
Sonic Boom's Avatar
Sonic Boom
I run a original Ford Standard Exhaust cam in mine.
Although i'd highly recommend Newmans Billet cams if you wanted a Standard Spec but a new cam.
Rich
Old Feb 3, 2014 | 01:05 PM
delbee1's Avatar
delbee1
[QUOTE=Sonic Boom;6419029]I run a original Ford Standard Exhaust cam in mine.
Rich[/QUOTE
Thanks for the reply
Old Feb 6, 2014 | 07:15 PM
Jase-C19 WTH's Avatar
Jase-C19 WTH
439.2 bhp on standard inlet and exhaust.
Old Feb 7, 2014 | 06:02 PM
jim callear's Avatar
jim callear
bd16 inlet and bd15 outlet on mine
Old Feb 8, 2014 | 10:57 AM
delbee1's Avatar
delbee1
What power does yourrun with those cams??? Does having the BD15 exhaust make it laggy??
Old Feb 8, 2014 | 11:51 AM
jim callear
it made 502 with a misfire as for lag its not that bad
Old Feb 8, 2014 | 01:47 PM
Sonic Boom's Avatar
Sonic Boom
Mine makes 590 bhp and 578 ft/lb of torque on a standard exhaust cam.
Rich
Old Feb 8, 2014 | 02:04 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Rich
Im not allowed to say the Power that Mark stops using a standard exhaust cam but its a whole chunk higher than you have just quoted.
Old Feb 8, 2014 | 05:02 PM
Sonic Boom's Avatar
Sonic Boom
Yes there really is no need to change the exhaust cam unless you want to rev the nuts off it on solid followers or go mega power.
Rich
Old Feb 11, 2014 | 10:15 AM
delbee1's Avatar
delbee1
Rich
Thanks for the replys.... interesting stuff
So what affects does putting a bigger exhaust cam have??
fuzzy
21
Feb 15, 2016 10:26 PM
A.t.p
Aug 15, 2015 11:37 AM
Aug 14, 2015 07:29 AM
M K
Aug 12, 2015 06:57 PM
Old ford
Jul 31, 2015 06:50 AM
