is it fixable??
Old Jan 30, 2014 | 06:47 AM
appo94's Avatar
appo94
Default is it fixable??
Finally pulled my finger out and started sortin the onion out, fair bit of welding needs doin so far but nothing that cant be fixed, there is something I need some help with tho...after ripping the sopping wet, mouldy old roofliining out I established where the wet was coming from, the rear of the panel where the sunroof sits when open has rusted all the way through at the drainage pipes on each corner an has spread up to just before the middle door Pilar (on this panel, no rust on anyrhing structual...yet!) is this something that can be fixed with a couple plates or a bit of small box section? From what I can see at the minute the rust is still only on this panel and hasn't spread to the outer roof panel or pillars...I will try and get some pictures up of the problem as soon as I get to a proper computer
Old Jan 30, 2014 | 11:24 AM
Anything can be fixed with a welder matey.
Old Jan 30, 2014 | 03:51 PM
slammedorion's Avatar
slammedorion
Pics might help...
Old Jan 30, 2014 | 04:23 PM
Cameron's Avatar
Cameron
like this?
just welded mine up then sprayed waxoil inside the recess
Had it on the road for 2 years since and it didnt seem to get any worse, ive just binned my sunroof in favour of a carbon roof which im fetching on Saturday so no more worrying about leaky sunroofs.
Old Jan 30, 2014 | 04:24 PM
Cameron's Avatar
Cameron
oh and be careful how much heat you put into the roof as it warps like crazy!
Old Jan 30, 2014 | 05:00 PM
appo94's Avatar
appo94
Yeah Cameron its gone exactly like that mate, when I remove the sunroof will the runners come out with? Where I need to cut is directly under the runners
Old Jan 30, 2014 | 05:23 PM
appo94's Avatar
appo94
Is this a result of the pipes being blocked and shitty seals/rubbers? I managed to snap the top of the pipe earlier tryin to get it off and they look like a pain in the arse to replace..if they can be replaced
Old Jan 30, 2014 | 06:02 PM
Cameron's Avatar
Cameron
Remove the glass first, its 6 screws, the actual sunroof tray itself is only secured by some screws around where the glass sits, you can cut the back part of the tray no problems
Old Jan 30, 2014 | 06:07 PM
Cameron's Avatar
Cameron
Its just a water trap mate, real bad design
Old Jan 31, 2014 | 03:30 AM
appo94's Avatar
appo94
yeah its not too clever really is it, pipes cleared now tho, hopefully get the glass out and crap metal cut out 2mora and get it all welded up and ready for paint
Old Jan 31, 2014 | 08:11 AM
slammedorion
Can you not make a new piece up and silkoflex it up there?
Would save getting the roof hot...?
Old Jan 31, 2014 | 06:46 PM
appo94's Avatar
appo94
i did originally think this, it doesnt seem to be welded on as it as..not that i can see anyway but i havent really looked at how its held there i've been more worried about sortin the rust..do you know anyone that might stock this panel then fella? i gave a couple of local body shops and scrappies a ring earlier today but no joy.
KW-rscos
33
Oct 23, 2025 05:37 PM
Red_bull
May 6, 2014 12:00 AM
wardyxr2
Sep 8, 2006 09:14 PM
