HELP fitting t34 to 2wd saph
I have got a t34 for me 2wd saph but have a few problems fitting it and am getting a bit pissed of now.
WHAT ACTUATOR BRACKET DO YOU USE. I was under the impresion that the 2wd bracket would fit but it dont
I drilled the holes out so it does line up but now the actuator is about half inch away from the wastegate arm
So if anyone could shed some light on the situation it would be mucho appreciated
I made my own out of a bit of plate, however you can widen the holes and then fit penny washers under the bolt heads
Pugo
sorry didn't see the actuator problem, you need a 2wd actuator and end fitting...!
Pugo
kosienutter
31
Aug 22, 2015 09:55 AM
155lee
Aug 14, 2015 11:21 AM
lockie
Jul 31, 2015 10:03 PM
