Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Revving up on its own
Old Jan 27, 2014 | 01:59 PM
paulmtdci's Avatar
paulmtdci
Default Revving up on its own
02 Estate TDCI,it's started revving up on its own,not all the time tho,goes up to about 2k and sits there,sometimes stops doing it on it's own,sometimes have to switch it off to stop it,ideas please.
Ta
Paul
Old Jan 27, 2014 | 08:08 PM
uruk hai's Avatar
uruk hai
Is it using any oil since this problem started ?
Old Jan 27, 2014 | 08:21 PM
Dave-Rs's Avatar
Dave-Rs
as said check oil as turbo could be fucked and the car running on oil and could run on higher and blow the engine
Old Jan 28, 2014 | 02:34 PM
paulmtdci's Avatar
paulmtdci
Default revving
ok i'll check the oil,see if its used any,thanx for the replies
Paul
Old Jan 28, 2014 | 05:32 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
Could it be the butterfly flap on trottle body?
Old Jan 28, 2014 | 05:39 PM
GVK.'s Avatar
GVK.
The flap is only used to starve the engine of air on shut-off to stop it 'running-on'
For it to be revving on it's own it has to be fuel or oil getting into the cylinders.
Old Jan 29, 2014 | 06:55 PM
paulmtdci's Avatar
paulmtdci
Default Revving
Hasn't done it since I checked the oil,I'll check it again at the weekend to see if it's using any or not
Ta
Paul
Old Feb 4, 2014 | 04:40 PM
paulmtdci's Avatar
paulmtdci
Wouldn't it smoke as it was revving high if it was running on its oil? Revs up to about 1800 revs and sits there,not done for a week or so but did it 3 or 4 times today,no blue smoke tho,get black smoke when the engines working hard tho.
Paul
Old Feb 12, 2014 | 11:58 PM
Cardie's Avatar
Cardie
Soon as it does it take the key out to see if it is running on its own, if it goes straight off then theres no problem with it running on its own lube, probably a throttle pedal problem.
Old Feb 13, 2014 | 11:22 AM
paulmtdci's Avatar
paulmtdci
Doesnt run on when switched off when revving,ebay it is for an accelerator pedal then!!,any other issues that could cause the revving up?
Thanks for the replies
Paul
Old Feb 13, 2014 | 05:49 PM
GVK.'s Avatar
GVK.
I've only ever seen the throttle pedals on these fail to cause lack of acceleration, ie car will start, but only run on idle.
Inside the throttle pedal you have 2 sliding potentiometers (APP1 & APP2) basically one sensor goes from 0-5v the other goes 5-0v depending on throttle position and the outputs are worked out by the PCM to give the true pedal postion..
They do this to stop there being any chance of a 'run-away' situation where the engine can rev on it's own.
If any of the APP sensors fail the PCM will only allow a certain amount of torque to be produced, as I say, usually if the pedal fails it will only allow idle speed.
Happy to be proved wrong of course.
kosienutter
31
Aug 22, 2015 09:55 AM
JoeyBoyden
Aug 18, 2015 05:56 PM
Adam-M
22
Aug 10, 2015 10:46 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
3door
Dec 11, 2003 04:26 PM
