Noticed a suspension mod on the 3dr
Its got Grayson hard rubber or plastic type things between the springs front and rear...
Now apparently they help traction on the rear as it reduces squat in which i assume reduces the camber.....views???
The old Caravan assistor trick eh
Got them on mine at the moment Phil, until i get some coilovers
Does well to stop the squat as me and Pops found out at brunters. TIB ran them when he did has awesome 0-60 times
Originally Posted by ImaRacing 700
So if i bung the Rainbird shims on aswell....it may give some adequate grip over standard.....i may need a tad extra grip with the new engine
Or is that not DiY enough for you
Its cause although squat is good for traction from a weight transfer point of view, on cossies in cambers in the wheels soo badly it fucks up the traction, so better off without the squat, so people bash on the caravan pull spring assisters.
Tiff....."i will suck it see" if you dont mind me using the famous NMS motto
I like to see what fails before changing
"i will suck it AND see"
It wont be a case of solid rubber caravan assistors failing Phil
Like ROD has said a lot of times before, it is the whole package, not just the engine that will get you a good topspeed.
Do it right Phil if you want to play with the big boys
SMILER258
Sep 28, 2015 09:04 AM
