Ford KA Discuss your Ford KA here!
Ford KA 2001 1.3, floppy brakes and clutch
Old Jan 20, 2014 | 07:53 PM
Bukko89's Avatar
Bukko89
Default Ford KA 2001 1.3, floppy brakes and clutch
Hello,
Have a 2001 Ford KA, I have replaced the clutch as there was a knocking noise coming from the clutch, turns out pressure plate straps had broken, new clutch fitted all went well...
I now cannot engage gears when the clutch is depressed, I have bled the clutch several times, no air bubbles at all but the pedal still feels limp and not doing a lot. To make things worse the brakes also now feel as though they have got air in them, bled those as well, again no air bubbles.
I have bled three of the pipes coming from the master cylinder itself but again no luck.
Is there something I am missing?? has anyone got any ideas??? as I really do not want to take it to the garage!
Also if someone could check on the same year KA for me does the servo and whole unit move/lean forward when the brakes are applied?? would be helpful to know if everyones servo moves about??
Old Jan 24, 2014 | 02:17 PM
Bukko89's Avatar
Bukko89
Even if someone could tell me if their servo moves when the brakes are applied would be a great help and starting point.
Thanks
jessie_rs
11
Jun 3, 2019 04:57 PM
druidgetafix
Aug 15, 2015 10:22 AM
Bobby9779
Aug 11, 2015 06:47 PM
Old ford
Jul 31, 2015 06:50 AM
