Castor
Old Jan 20, 2014 | 01:11 PM
2Litre's Avatar
2Litre
Default Castor
Hi all- does anyone know the standard castor of a 3 door?
Thanks for your help.
Tim.
Old Jan 20, 2014 | 09:08 PM
Mike1's Avatar
Mike1
Tim.
It should be around 2.5 degrees with the early ARB ( H13 type ).
If it's had the later H14 type ( offered as a recall/or on late builds and also found on RS500 and 2wd Sapphire ) it should be around 3.5 degrees. The ARB type is marked on the bar end if you look hard. With the H14 the wheel will sit quite close to the front of the arch and might even foul the front bumper on heavy lock.
Old Jan 21, 2014 | 11:43 AM
2Litre's Avatar
2Litre
Default ARB
Thanks very much Mike, mine is a H13. Are H13 ARB's hard to come by these days?
Thanks very much.
Tim.
Fezman1
Oct 2, 2015 01:22 PM
vibrating_cake
Dec 6, 2007 10:43 AM
Fiecos Dan
Jul 16, 2006 11:45 PM
