oil pump priming
Old Jan 14, 2014 | 04:44 PM
timsrs's Avatar
timsrs
Default oil pump priming
I have given my 2wd a freshen up and today filled with oil and primed using a flexi drive in the dizzy hole.
Turned clockwise and oil came faily quicky to the turbo feed, but what i did notice is the dizzy hole also filled with oil....
is this normal when doing this type of priming.....
Regards
Old Jan 14, 2014 | 06:09 PM
dug112y's Avatar
dug112y
passionford pro
anything connected to the oil pressure side will get oil to it.
Old Jan 14, 2014 | 07:14 PM
timsrs's Avatar
timsrs
OK anyone else got any thoughts
Old Jan 15, 2014 | 05:16 PM
Paul_RS's Avatar
Paul_RS
Pretty sure the dizzy seals that hole once fitted?
Old Jan 15, 2014 | 07:33 PM
timsrs's Avatar
timsrs
Thanks.....i am sure it will but to be honest did'nt quite expect alot of oil comming from there.
Old Jan 17, 2014 | 07:23 PM
timsrs's Avatar
timsrs
Any more comments engine is being fitted next week, and want to make sure its right
Cheers guys
Old Jan 17, 2014 | 08:14 PM
cossie moon's Avatar
cossie moon
Durham RSOC member
Yes you will have oil there and the dizzy seal will seal that once fitted.
Old Jan 17, 2014 | 08:42 PM
timsrs's Avatar
timsrs
Thanks for the advice,
Old Jan 17, 2014 | 11:19 PM
Paul_RS's Avatar
Paul_RS
Once you are ready to fire it up, pull the coil off and crank the engine over. That will build some oil pressure before you start the car.
Old Jan 18, 2014 | 08:34 AM
timsrs's Avatar
timsrs
Thanks Paul...Yep was goin to do this...
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 27, 2015 04:55 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
