Fault on st220 boot popper?
It's started popping open whilest I'm driving and you can hear the mechanism opening randomly. Doesn't do it when no key is in.
But what I also have noticed is I can't open it at boot now via the button.
Works fine on key and button on dash? Cheers
it'll be the microswitch on the boot button
tricky little fucker to get one as you have to dismantle the little bits that get in the way in order to remove the boot trim it's located in
when you pull the boot trim panel off there should be 6 10mm or 11mm nuts holding the panel in place, but it's complicated because there are wires and stuff for the rest of the boot running along there and the number plate lights can be a right pain in the arse to get apart as they may have rusted into place
the boot switch is a tiny little wire you unclip so take it all apart and see if it just needs greasing or a new switch before you order a new one
if you can get to the little wire yes, but it may not solve your problem
worst case scenario is that the door master control is faulty which is a fair amount of work to replace
Just found out that is popping even with key out n when you open the front doors? Also when you turn ignition on etc. Sounds like there is an electrical fault and something is causing it to open the switch? Maybe an earth fault?
it could be the lock that's faulty then
will it pop with the remote? mine did and with the key but not with either button on the car, either the dash or the boot lid
eventually the lock gave up and was fucked but i luckily managed to find a replacement which fixed the problem
It works fine on key fine on dash switch but not on rear boot switch? I fit a front splitter today with self tappers, but I doubt that has anything to do with it.
It's sorted itself out not done it since. Woke up next morning and was fine. Works on boot too so I think you were right about the micro switch. Cheers guys
Si B
Sep 12, 2015 06:49 AM
chris m1
Sep 7, 2015 08:02 PM
