Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
Pinto
Old Jan 3, 2014 | 09:03 PM
Mark315's Avatar
Mark315
Default Pinto
Last year I got hold of a low mileage 2ltr pinto with a 205 block and unleaded head, it came out of a Royal mail van ...
I rebuilt the motor to go in my 63 Ford and ran it about last season but found it gutless but very good on fuel and pulls like a freight train uphill..
Since then I have done some research an found it to be a Low Compression motor....
How can I make it perform like a pinto should as cheap as poss....
Has anybody got any advice on these...
Old Jan 6, 2014 | 09:24 PM
soft spot for mk2 escorts's Avatar
Remove the head and have it skimmed, it sounds as if it is standard and there is plenty of room for skimming. Put a good head gasket back on felpro or similar check out Burtons site
Old Jan 12, 2014 | 10:31 AM
caprizetec170's Avatar
caprizetec170
Was it a carb or injection engine, think transit engine also use a single choke vv carb and 1600 profile cam so both those need swapping too
Old Jan 12, 2014 | 10:53 AM
DAN400's Avatar
DAN400
the pistons also sit down the bore in the transit engines
to be right the enigine needs stripped and the block decked or change the pistons,
unless this is done you might as well piss against the wind
Old Jan 12, 2014 | 01:09 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Lower compression than 2.0 pinto for a car. 1.6 cam and vv carb. Also has bigger flywheel for 9.5 inch clutch. Cheap way to get a 205 block though thats not been stressed
Old Jan 12, 2014 | 09:23 PM
Mark315's Avatar
Mark315
The pistons are level with the block ,and the block is stamped AW which means injection It is fitted with a twin chock and the can shaft that came with the motor..
Are you saying that I should try to get a 1600 cam and that should make it better, That's if the cam is totally different ...the one that's in that is..
Old Jan 12, 2014 | 09:28 PM
Mark315's Avatar
Mark315
Dan the pistons a level with the top of the block...
Would a head skim make any difference..
Old Jan 12, 2014 | 09:50 PM
caprizetec170
No what im saying is that transit engines had 1600 cams to start with, good for low down torque but gutless up top
What you need is a fast road or high torque cam for a 2 liter pinto
What year transit did your engine come from had it injection fitted when you got it? i wouldn't read to much into block stampings
AV AW AX are all just transit blocks from what i could find
Old Jan 12, 2014 | 10:01 PM
DAN400's Avatar
DAN400
id a transit engine for stockcar racing back in the day and it was unreal slow,
when I pulled the head of the pistons sat down the bore, I cant remember how much but im near sure it was by a few mm
for all it would take to skimmed the head I suppose its worth a try mate
don't be scared to take a good bit off
Old Jan 12, 2014 | 10:15 PM
Mark315's Avatar
Mark315
The engine came out of a 1990 transit and it had a single carb on it ....
I wish it was injection, I don't wish to go mega fast just give it more guts..
Old Jan 12, 2014 | 10:33 PM
caprizetec170
if was mine id do compression test first find out what it is then cam swap even HC pinto's gain a good bit from cam swaps really livens them up
I thought only unleaded pinto's were injections with better flowing head also
Old Jan 12, 2014 | 10:34 PM
Mark315's Avatar
Mark315
The standard 1500 has more bump than THIS...
Old Jan 12, 2014 | 10:42 PM
Mark315's Avatar
Mark315
The head is unleaded but I never did it.. I checked it though the web when I cleaned it up..
Old Jan 27, 2014 | 02:10 PM
sridgett's Avatar
sridgett
The only way is dagenham
If your engine is low compression. I think all you have to do is change the pistons.
chowfornow
14
Jan 5, 2019 09:01 PM
Daniel Howard
Oct 3, 2015 10:44 PM
20/20 vision
Sep 29, 2015 11:27 AM
chowfornow
Sep 19, 2015 10:47 PM
steff19
Escort Range
Sep 9, 2015 10:14 PM
