Ford sierra sapphire turbo technics pinto
Hi all just got hold of this little beaut!
2.0 pinto efi turbo technics tt075
I must say I shat a brick when first driving this very unexpected delivery of power and wheelspin..
Payed £1200 for this with full history
All the plans are is to fit my sapphire cosworth alloys and a bigger intercooler and new boost hoses and then just do engine but by bit, I'm not looking for huge power but would like to see 200bhp out of it
What you guys think?
Yeah pepper pots are just winter set I'm looking for some cosworth lattice or another kind but got to shift my st170 engine cheap lol also the prev owner we'll the only other owner, had a new turbo put on it in 2008 costing a mere £650.
And it has damper adjustable sspensin with rs cosworth stamped on them?
I used to live next door to this car, looked smart with escort cos rims on it. Has a nice amount of power for having fun. I have some pics of it somewhere.
Hi guys I've hit a massive rock and an confused lol
Last night I started up the saff and let it run for 10 mins or so before I drive it, as driving up my road I noticed the rev gauge and fuel and the temp gauge was all on the bottom ( not working )
Battery light came on ect run like poo,
I'm guessing the alternator has lost its balls and given up it has a new battery on too,
I've taken leads off batt and left for 10 mins to see if that cured and now doesn't turn over fast enought like batt is flat.
If anyone can help would be great ful cheers
Make sure the leads to the battery are well connected, as a poor connection there causes those symptoms.
You can check the alternating charging voltage by measuring across the battery with the engine running, should be 14volts. This will confirm the alternator is working.
It's all done guys I took one of the other fuses out and they clearly have got damp ect corroded so when and got new ones for the. Whole fuse box
omit row I got to tackle the indicators as they don't work, anyone know where the relay is?
I found this car as an upset rolling shell in a field.
its missing its history, and missing its engine and the car is in a million bits. Does anyone know what happened to the old girl??
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Aug 9, 2015 07:03 PM
