Ford Puma Discuss the Ford Puma here!
Idle speed problems
Old Dec 29, 2013 | 09:24 AM
Jay Todd's Avatar
Jay Todd
Default Idle speed problems
Can anyone help me please I can't get my head around this at all, I have a ford puma R reg when I first start the car the revs are at about a thousand rpm then once it's been driven for a while when you come to a complete stop the revs drop to just above five hundred rpm, but here's the quirky thing while the car is still in motion with the clutch dipped or out of gear the revs will stay at just under a thousand rpm its only when the car comes to a complete stop they drop it is causing the car to stall when I try to pull away because as soon as you get the biting point on the clutch the revs plumit to almost zero, I would be grateful for any help, Many thanks Jay
Old Dec 29, 2013 | 09:53 AM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Either you have a dirty idle speed control valve which will be somewhere on the inlet manifold / throttle body are. Very common issue. Remove and clean this and you'll probably be ok. Worst case you need a new one. Dont know if these have a vehicle speed sensor like the focus and mondeo as they are often a problem as well
Old Dec 29, 2013 | 10:16 AM
Jay Todd's Avatar
Jay Todd
Many thanks for your quick response much appreciated, I will endeavour to find this part as I'm not mechanically minded n disabled to boot
Old Dec 29, 2013 | 10:41 AM
JamesH's Avatar
JamesH
It will be on the inlet manifold
TPM961
Jan 15, 2018 10:50 AM
RSmark84
Sep 13, 2015 01:29 PM
Marino
Sep 12, 2015 11:10 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
