Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
99 focus s-se cylinder heads
Old Dec 22, 2013 | 01:57 PM
Fardman's Avatar
Fardman
Default 99 focus s-se cylinder heads
I have 99 focus 1.6 74kw zetec-s and i have to change that cylinder head, so can i use zetec-se model cylinder head in my s-version engine? Same lenght valves etc...????
Thanks
Old Dec 22, 2013 | 03:56 PM
Twizz's Avatar
Twizz
Out of many, we are one.
Taken from another thread:
Originally Posted by Bailes1992
Your S will have a MAF sensor and your SE will have a MAP sensor.
You can either just not plug the MAP in (It's located in the inlet manifold) or you can put your inlet manifold from your original engine on the new engine.
Another thread:
Originally Posted by Rcjm88
Phase 1 and 2 engines are different but heads can be changed. Do they both have a plastic cam cover or does one have a metal one?
The valves are different in them though so you cant swap over them over.
If you want any help on the SE or need any parts see this man: www.shawspeed.com
and finally:
If they are both plastic cover they will be the same. Or if you want to just replace the valves call the guy on the link I posted. He might well have some 2nd hand ones about too.
Phase 1 heads have longer valves and different style of buckets as said
So yes, you can swap the heads over BUT the valves depending on whether its a phase one or two are different (ones got a plastic cam cover and the other is metal).
Could bang a 1.7 Puma engine in there? More power
Edit: When removing the valves if you do, make sure not to mix up the buckets/shims... I drew out a diagram and labeled each one when I changed mine.
gavt123
Sep 5, 2015 10:03 AM
Fordmad!
Sep 4, 2015 01:42 PM
hopper350
Sep 4, 2015 12:53 AM
Marcus L
Aug 29, 2015 02:18 PM
turbotrev
Aug 22, 2015 11:41 AM
