Transit Connect write off project
Old Dec 7, 2013 | 03:15 PM
dannyboy89's Avatar
dannyboy89
Default Transit Connect write off project
Having taken delivery of my new Van yesterday I thort I'd start up a project thread as I plan to repair it and also make it a little bit different to most connects at the same time. It's a 2007 swb with 96000 on the clock. It's a cat c write off hit in the front. Pics to follow soon. First thing to do is repair all the damage which means a big strip down and make a parts list, so if anyone has any front end parts for a transit connect lying around they want rid of let me know lol. I'll try and update this as the project goes on so everyone can see it transform.
Old Dec 7, 2013 | 03:24 PM
dannyboy89's Avatar
dannyboy89
Old Dec 7, 2013 | 03:57 PM
Good luck with the project matey. These are a good van if rhere looked after.
Old Dec 7, 2013 | 04:08 PM
dannyboy89's Avatar
dannyboy89
Thanks mate, I found loads of service history and receipts in the glove box so it seems to have been well looked after. Also had the cambelt done in September this year.
Old Dec 7, 2013 | 04:17 PM
dannyboy89's Avatar
dannyboy89
Old Dec 7, 2013 | 04:20 PM
Cool. The cam belts are a piece of piss to do. The hard part about them is taking the cam cover off to lock the cam.
Old Dec 8, 2013 | 08:55 PM
dannyboy89's Avatar
dannyboy89
Stripped some of the front end down today to get an idea of what parts I can save and what I need new. Found the rad is fairly bent so will fit a new one, although its still holding water. Fortunately the intercooler is fine but all the trims around it need replacing. I'm gonna have a go at repairing the bumper tho which should save some cash. But may have to get a new cross member and definitely a new front panel. checked the oil and all fluids and all is well. But it did run out of diesel when I was having a listen to the engine running. Got some pics of it stripped too.
Old Dec 8, 2013 | 09:01 PM
dannyboy89's Avatar
dannyboy89
[URL=http://s207.photobucket.com/user/fiesta200/media/Mobile%20Uploads/DSC_0025.jpg.html]Name:  DSC_0025.jpg
Old Dec 8, 2013 | 09:02 PM
dannyboy89's Avatar
dannyboy89
Can anyone tell me how to tell if it's a tddi or tdci too?
Old Dec 8, 2013 | 09:45 PM
dojj's Avatar
dojj
Resident Wrestling Legend
when we had one like this at our place most of the front end was only bolted together
Old Dec 8, 2013 | 10:01 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
see if it has 1 pipe or 4 pipes coming from the pump
1 goes to common rail, then injectors = Ci
4 go direct to injectors = Di
Old Dec 9, 2013 | 09:50 AM
dannyboy89's Avatar
dannyboy89
Yeah it's all bolt on, might have to do a small repair to the inner wings. I'm a panel beater so won't cause me too much trouble if it has been damaged further back.
Thanks for that, il check for sure next time I work on it but from what I remember seeing itl be a tddi then.
Old Dec 9, 2013 | 03:23 PM
0150carmac's Avatar
0150carmac
look forward to reading the updates
Old Dec 10, 2013 | 09:08 PM
mercury grey minter's Avatar
mercury grey minter
How much did you pay for the van?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
gambo08
Feb 4, 2016 10:49 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
SMILER258
Sep 28, 2015 09:04 AM
