Saph jacking points - are any replacements available ?
Old Dec 4, 2013 | 09:13 PM
wormeo's Avatar
wormeo
Default Saph jacking points - are any replacements available ?
Hi ,
I am after buying some new jacking points to weld in my Saph - mine are in a sorry state and need tidying , I want to keep the original look and not just weld plates around them ,
Does anyone know of anywhere I can buy some genuine ford or is there anywhere that has copied them ?
Thanks
Old Dec 5, 2013 | 03:47 PM
Paul_RS's Avatar
Paul_RS
I think it's a case of getting a metalworker to remake them?
Old Dec 5, 2013 | 07:22 PM
Ive read/seen on a few restos that people cut holes in the floor above the jacking points then knock the jacking points out into shape.
Old Dec 5, 2013 | 09:52 PM
Mark V8's Avatar
Mark V8
Chop out the floor and give it a good bashing!
Old Dec 5, 2013 | 10:22 PM
botters's Avatar
botters
competant bodger
just get a body shop to use a pin welder on them to weld pins on and slide hammer them down into shape, cutting the floor to get too them is a bit extreme unless the floor is rotten anyway
Old Dec 6, 2013 | 07:24 AM
Thats a good idea botters.
Old Dec 6, 2013 | 04:28 PM
wormeo's Avatar
wormeo
Thanks for the replies , the floor isn't rotten just the jacking area is a mess from previous owners , I have a pin puller from when I used to do bodywork will give it a go,
Would think the metal would be too tough for the puller but will try before cutting the floor , have to do it this winter otherwise I will probably never do it !
Thanks again very helpful !
Old Dec 6, 2013 | 05:38 PM
botters's Avatar
botters
competant bodger
you can get different ends for the pin puller one will actually weld a thread on, wurth sell the threads and adapter iirc
Old Dec 6, 2013 | 05:56 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
I removed(cut) them from the floor on mine beat them back in to shape and welded them back on and filled them with cavity wax!
job done
Old Dec 7, 2013 | 04:39 PM
Good idea matt.
Old Dec 7, 2013 | 07:51 PM
johnnycortina's Avatar
johnnycortina
job done
Definitely a job I plan to do on my sapphire - it bugs me when I look at them, the dented state of them. If I go to a tyre place, I tell them where to put the trolley jack. I wont let them near car on their own.
Old Dec 8, 2013 | 10:42 AM
Fezman1's Avatar
Fezman1
I had the same problem on my saff. I tried pulling & beating them out but they were abit crusty and f**ked with 24years of being jacked wrong & abused.lol.
I ended up using a piece of 50x50x2 box section, hours of cutting, welding, shaping & drilling holes to match the original.
First one took around 6 hours to get it looking right - but they are mega strong & look spot on.
Old Dec 9, 2013 | 09:28 PM
Mark V8's Avatar
Mark V8
Not sure if the weld on pin puller things would work
I had to beat the crap out of mine with a rectangular steel bar and club hammer.
Came out alright in the end though...
Old Dec 9, 2013 | 10:21 PM
paddy heffernan's Avatar
paddy heffernan
heffo
Default jacking points
i made up new ones to fit over existing ones out of zintec and seam welded .looks perfect and a lot stronger
Old Dec 9, 2013 | 11:15 PM
Rob Virgo's Avatar
Rob Virgo
So what are they for then ...
dojj
28
Sep 11, 2015 10:00 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
Adam Graham
Sep 6, 2015 06:04 AM
rsturbo27
Sep 5, 2015 05:08 PM
hopper350
Sep 4, 2015 12:53 AM
