3 door loom
Old Dec 1, 2013 | 06:13 PM
paddy heffernan's Avatar
paddy heffernan
heffo
Default 3 door loom
hi guys i got a new braided loom last year for 3 door cossie .i tried to fit it today but which ever way i route it dosent sit right.it branches into 2 main bundles one has injector plugs this jumps up on back of fuel rail and travels along rail . the other branch if i run this way has a tee off it for coil and ignition amp that wont reach .if i run along chassis leg its also wrong .any help appreciated .also where loom comes through grommet should it go over or under abs block
Old Dec 1, 2013 | 07:51 PM
Nash's Avatar
Nash
Cake lover!
The loom should sit on top of the inlet and then down the front of it. The loom should then run under the abs block. Can you not lay the loom down next to your old loom to make sure they are the same length. This is the only picture I can find of my 3 dr that shows you how it sits.
Old Dec 1, 2013 | 07:59 PM
james kiely's Avatar
james kiely
paddy mine goes over the abs block in the little gap between the abs block and the battery
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mark V8
Sep 13, 2015 09:34 AM
ward1174
Sep 12, 2015 03:34 AM
dms04
Sep 11, 2015 01:57 PM
