Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Focus 1.6tdci's - are they as bad as people make out?
Old Dec 1, 2013 | 06:03 PM
RichieST's Avatar
RichieST
Default Focus 1.6tdci's - are they as bad as people make out?
Evening all
Been looking for a new car for the wife for a little while now, and a Focus 1.6 tdci had popped up locally, 56 plate, 76k on the clock with full history.
Done a lot of research on them and they seem to be the worst of the bunch, with oil sludging, injector leaks and turbo failure problems. Is this the case for all of them, or is it just something that can happen due to poor maintenance? There are a lot of them out there, so not sure weather the problems you hear of are actually rare, it's just the volume of them on the road that makes it seem common.
Thanks in advance
Rich
Old Dec 1, 2013 | 06:13 PM
pani_k's Avatar
pani_k
PassionFORD Member
I'm sure someone more knowledgeable will pop along in a sec but IIRC the turbo failure issues are due to a poor oil routing design that inherently causes blockage and starvation. These are the Peugeot engines the 1.6's.
Old Dec 1, 2013 | 06:19 PM
DangerousBryan's Avatar
DangerousBryan
Yes,there crap. Once the turbo go's the whole engine is pretty much scrap. We now turn them away and were a ford dealer. Even if you clean all the filters out they still go again. If its a 110ps they have a dpf on them that needs replacing every 75000 miles and the dpf fluid topping up every 37500 miles. Engines can get very noisey over time from the top end. Just because your going to maintain it doesn't mean the previous owner has. They hate short journeys and will sludge up the oil pretty quick.
Old Dec 1, 2013 | 06:20 PM
GVK.'s Avatar
GVK.
Exactly that. There's a very complex TSB to follow if replacing the turbo with a lot of bits needing replacement to stop follow on failures.
They're pretty gutless too.
My sister saw one for sale recently, she's got a new job and travels more miles so her Sport Ka is a bit juicy. I advised her they can be troublesome and slow.
She had to go on a trip for work in her new job, from Lincs to Coventry in her works pool car (Focus 1.6 TDCI)
She thanked me for advising her against one as in her words it was "Gutless and rubbish"
Old Dec 1, 2013 | 06:22 PM
RSBryden's Avatar
RSBryden
10 Year Member
I have a 110 tdci focus buddy, it's done 110k miles and is solid , I did hbe a leaky injector and a problem with the dpf,
I sorted the injector and puting a egr valve blanking plate and she is good as gold, not had a problem since
RSBryden's Avatar
RSBryden
10 Year Member
1.6 tdci 3door focus
Old Dec 1, 2013 | 07:08 PM
RichieST's Avatar
RichieST
Oh dear that doesn't sound too good, guess I should avoid it then. Shame really as it seems a bit of a bargain.
What are the 1.8 tdci's like then? Or can anyone suggest anything else similar to look for? Went and had a look at a mazda 3 today, thing was awful. Just dunno what else to look at!
Need something that is happy on the motorway, Focus sized, about 2006 onwards, economical, reliable and safe for the little one. Got about £3.5k to spend, £4k tops!
Old Dec 1, 2013 | 07:12 PM
GVK.'s Avatar
GVK.
1.8 is a modified version of the old Lynx TDCI engine as per mk1 Focus, these do have the odd injector issues, but other than that pretty reliable from what I see.
Old Dec 1, 2013 | 07:17 PM
RichieST's Avatar
RichieST
Ah, so the same single cam unit that's in my mk4 mondeo then. I can do 50mpg in it when driving normally, so Focus should do a bit better.
Old Dec 1, 2013 | 07:18 PM
GVK.'s Avatar
GVK.
If I had to choose I'd have the 1.8 over a 1.6!
Billy_RS
16
Oct 11, 2025 09:41 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
track.focus'd
Aug 12, 2015 05:53 PM
