hart inlet on a stage 3 cossie
guys is their any benefit using my hart inlet on my saff as i will only be going to stage 3+ [400 ponies]maximum as i want to give the original engine block the chance to live on for a bit .
if its of no benefit ,i may just sell it on
maybe jon
330 is stage 2 andy
I cant see any reason how the one that flows better could in anyway be a bad thing ... it may not be needed at that power level but it must drive better I would think
there could, due to size be a notable difference in "lag" the same as the difference between fitting a 500 size cooler vs standard cooler. most probably only notable on a rr printout and not in real world terms
I was thinking of replacing my rs500 inlet with a hart at 500hp but still don't know if there's a benefit at 500hp? I don't like the look of the hart compared to the 500 inlet!!
I would go for a late escos inlet and it keeps the bay looking stock as a result. I have put all the cossie types side by side and its by far the best for flow, even better with a bit of a dremel clean up inside of the casting
James - I'd fit it, looks super trick.
Also, Not sure if you bought the engine fully complete, but it was already fitted with a 4 x 4 inlet and also the inlet was also ported to match the head that Karl Norris did. All the inlet manifold is beautifully ported, it took me days to do. I also took it to my local technical college where they checked that all the ports were equal on an air flow bench. On the third attempt I got all four flowing perfectly even.
they do look sexy
i have the full engine with the ported trumpet section ,but i will probably have to take out the t4 cams you and karl had specced for the engine at the time as they will be overkill for 380bhp
ps i will be updating the build threas in the next few days lol
the thing is glenn i have to have it mapped in the uk probably so have to go with one and stick with it mate
I have installed a Hart (autospecialist type) inlet manifold on my engine (stage 3 and T35), I also have installed an AB07 inlet camshaft to reduce the lag that this manifold creates, I saw a mid range power gain but know my engine creates power up to the rev limiter.
I believe that you can release the maximum bhp at this stage with this manifold but you must install an inlet manifold to help it
i dont want to tempt faith with the 205 block mate ,380/400 bhp will be loads for a road car
cheers matey , i think i will go down the abo7 route aswell .gt 35 is to big for me on this car, i just want a nice punchy setup
steve probably because i want to keep matching numbers lol
by the time you have it all done pete its expensive and i still have that 205 block to worry about
i want this car to be a good allrounder mate ,im not interested in chasing numbers
My next target is 420+hp from a T35 at 1,55 bar at high rpm (I know that it's difficult to do it, but I will try)
Indyrs
Dec 4, 2022 12:39 PM
