044 pump and inlet fittings & pre pump filter?
Old Nov 23, 2013 | 11:34 PM
Ade's Avatar
Ade
Fast Ford snapper
Arrow 044 pump and inlet fittings & pre pump filter?
My Saph has recently started to run lean, and suspicions are pointing towards to fuel supply. The pump looks original, and ancient, so going to upgrade to an 044 or equivalent.
Any recommendations for suppliers or alterative pumps?
Also I'm seeing that some places sell the pump without the Cosworth inlet pipe adapter. Would the original one from the car's regular fuel pump be the same?
Also looking to possibly fit a pre pump filter, as who knows what crap could be in the 25 year old tank... Any recommendations here too?
Edit: Did read one thread on here about the 044 not being able to suck through a filter when gravity fed? Any thoughts on this?
Old Nov 24, 2013 | 06:49 AM
big_wig_074's Avatar
big_wig_074
Genuine 044 pump has a filter gauze on the inlet.i just checked mine.
this is the kit i bought
http://www.ebay.co.uk/itm/Sierra-RS-...item25806c5f73
from Matt Lewis, from previous experience you want to eliminate all possible problems, including the wiring loom as that can be just as bad as a failing pump. Ł205 for piece of mind
Old Nov 24, 2013 | 01:47 PM
Ade's Avatar
Ade
Fast Ford snapper
An gauze on the actual screw in part of the inlet?
Can't see anyone mentioning that in adverts, not even MSD who usually detail everything...
http://www.ebay.co.uk/itm/The-Ultima...item3f27d5fa15
Old Nov 24, 2013 | 07:07 PM
big_wig_074
yes, where the adaptor screws in, look in there, theres a gauze in there. inside the pump itself.
Old Nov 24, 2013 | 10:41 PM
Ade's Avatar
Ade
Fast Ford snapper
Is it removable or can it be cleaned out at all?
Old Nov 25, 2013 | 03:51 PM
big_wig_074
dont think so no.how much crap do you think is in the tank?standard fuel filter will eradicate most of the crap.
Old Nov 25, 2013 | 09:56 PM
Ade's Avatar
Ade
Fast Ford snapper
No idea, but it's an old original tank... and the fuel pump comes before the filter, so not much help at protection there.
Old Nov 26, 2013 | 05:13 PM
big_wig_074
right,but the fuel system circulates doesnt it? and its just as easy to remove the inlet pipe and then tip the contents out of the pump as it is a removable filter?if youre THAT worried your tank is bad enough to require that then perhaps a new tank would be a better buy?any residue should only be from the fuel and tiny amounts from refuelling. you shouldnt have bits in the tank big enough to clog up a pump.
Old Nov 26, 2013 | 05:46 PM
Ade500's Avatar
Ade500
Fixing Fords
Like this Ade ?
Old Nov 26, 2013 | 08:49 PM
Caddyshack's Avatar
Caddyshack
If you cannot remove the gauze (can't remember) you could take it out and flow fuel the wrong way through it to flush the filter and then blow out with an air line (apply safety precautions) but I would just replace the pump. All 044 do seem to have the gauze.
Old Nov 27, 2013 | 09:38 AM
Ade's Avatar
Ade
Fast Ford snapper
I've ordered a new 044 pump now, but still unsure if a pre pump filter should be fitted?
Obviously makes sense in theory, but in practice can an 044 pump draw fuel through a filter?
Does it not need a direct gravity feed, or a lift pump to overcome the filter which would be inbetween it and the tank?
Ade500, apart from all the fancy connections, do you basically just have a a pre pump filter added in-line to the original configuration? And that works ok?
Old Nov 27, 2013 | 11:09 AM
Ade500's Avatar
Ade500
Fixing Fords
If you look through the paperwork that comes with the pump I'm fairly sure they say it should have one , that's why I fitted one.
Worked fine, they do different micron filters to suit.
http://www.demon-tweeks.co.uk/motors...rt-fuel-filter
But cheaper here
http://www.fuelpumpsonline.co.uk/syt...tion-194-p.asp
Old Nov 27, 2013 | 11:36 AM
carl n 1977's Avatar
carl n 1977
fitted one on mine last week with a new tank and at 68 pound for the filter they better be ok not had chance to try the car out yet
Old Nov 27, 2013 | 01:21 PM
Ade's Avatar
Ade
Fast Ford snapper
Cool, got a filter ordered too now!
Will be running a wideband permanently from now on too, so can make sure everything is working ok!
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
3doorcozmess
Aug 21, 2015 11:17 AM
ekjim
Aug 17, 2015 08:57 PM
track.focus'd
Aug 12, 2015 05:53 PM
