Need Picture of MK2 wheel hub
On the normal 4/5dr the shock and spring are combined & slides into the rear knuckle and it has a 'saddle' bracket that sits on the rear subframe on a pad.
The wagon has a seperate spring and shock.
Ours are like the 4/5 door exactly but they have rear drum here ours have disc. The wagon looks identical now that I think about it the hub nut was just throwing me off I forgot about the cover that goes over it our brakes look identical as well. Just need to know how the top of the knuckle is supported.
quick reason as to why I'm looking into this. Over here there are only two brake upgrade kits. Baer which is just a SVT Cobra brake rotor and caliper (great I have them ish) 13in rotor 2 spot caliper and then Willwoods same rotor but 4 spot caliper. Looking Hispec has 6 piston 14in kit. but they have bad standings among this forum and I know there have to be more kits out there...
steerfromdarear
28
Jan 29, 2016 06:14 PM
GTR_STU
Aug 28, 2015 01:02 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
