Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Water in back passenger footweel
Old Nov 12, 2013 | 09:13 PM
gadslon's Avatar
gadslon
Default Water in back passenger footweel
Hi after heavy rain last week I found that my mk1 has a leak passanger footwell behind driver was very wet this mornig I had there about 8 big cups of water. Anyone have any idea what can it be? And btw I have sunroof is it possible that its the problem? Many thanks
Old Nov 12, 2013 | 09:30 PM
The Underdog's Avatar
The Underdog
you cant fix stupid
usually its the seal that leaks on the scuttle panel because of poor refit after pollen filter change. have you had a service or the pollen filter changed recently?
Old Nov 13, 2013 | 07:12 AM
gadslon's Avatar
gadslon
I know what u mean but that is if u have leak in front passanger footwell and mine is in back behind driver
Old Dec 30, 2013 | 11:46 AM
milesy125's Avatar
milesy125
Im not sure if its any help to you now but i had the same problem with mine and it was the clutch master cylinder and i had the brake warning light come on as it was the clutch/brake fluid coming through the cylinder seal and on to the floor.
j.hammond1
30
Oct 31, 2021 05:28 PM
3drRich
Sep 13, 2015 07:32 PM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
