Escort front wheel settings
Hi ya Iv noticed the the front wheels on my escort sit in on the drivers side and out on the passenger side Iv changed the suspension and tca and now changing the sub frame but I was up a mates on sat an somebody turned up with a mint one and he has the same problem but the opposite way round has anybody else come across this ?
check the shocks arent kinked just where they clamp into the hub,its a common problem and even the slightest kink can throw the wheel out by quite a lot,it may not even be noticeable until you have the shock on the bench
