Witch gearbox would be better ??
Old Nov 4, 2013 | 05:01 PM
Pockets2012's Avatar
Pockets2012
Default Witch gearbox would be better ??
Hey guys
Just wondering witch gearbox do u think is better for my zetec build as il should be making a start after xmass
The two choices I know of is
Mtx 75 witch came with the mondeo
Ib5 out of a 1.8 focus witch ill have to buy but don't mind
I wana try for 400 bhp witch u all know
What are bad points of either ??
Is there any others ??
Just so u know its in a mk4 fezz
Thanks
Old Nov 4, 2013 | 05:10 PM
gjh's Avatar
gjh
I'd say with the power you want it'll have to be a focus RS gearbox, cant see the others lasting long (I could be wrong mind)
Old Nov 4, 2013 | 05:15 PM
Pockets2012
It's its cable ??
What name of gear box and how much mods to the cr would it be to fit
Old Nov 4, 2013 | 05:22 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
The focus rs box is a mtx75.
Old Nov 4, 2013 | 05:29 PM
pani_k's Avatar
pani_k
PassionFORD Member
MTx box without a doubt much stronger than an IB5 although a bog standard MTx I am not sure would be able to cope in the realms of 400bhp and matching torque. A Focus RS box is an MTxof some description but not the same as the one found in the Mondeo and 2.0 Focus.
Old Nov 4, 2013 | 05:44 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
A standard mtx75 with a uprated diff will be ok for 400bhp. The only weak point in a mtx is the standard diff
Old Nov 4, 2013 | 06:06 PM
Pockets2012
Ahh so defo mtx with out allday long
What kind of mods to the mk4 fezz body will I need ??
Old Nov 4, 2013 | 06:17 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
The only modding you shiukd habe to do to get the box in place is making mountd, chassie wise no chopping should be required
Old Nov 4, 2013 | 06:26 PM
Pockets2012
I was hoping that I know drivers mounts need doing any others ??
Old Nov 4, 2013 | 06:30 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
Yeh you will need a mount to hold the box to the chassie and a steady bar on the bottom of the box aswell,
Old Nov 4, 2013 | 06:36 PM
Pockets2012
Ahh ok I have all mount from the mondeo could I use any if them ??
Old Nov 4, 2013 | 06:40 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
Dont know but worth a try.make sure the driveshafts clear every thing before fixing the box in place
Old Nov 4, 2013 | 06:46 PM
Pockets2012
Well ill use the mondeo mounts wen I get the shafts done ill check will I be able to. Support it with two engine and gearbox top mount if not running ??
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
