General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Shouldn't take much to get that bhp out of it, decent valve springs, suitable turbo inlet and management, gearbox and clutch may be the limiting factors.
Cheers Jon will bell u about that,
Studabear- gunna chuck it together on ofab for the minute the bang an ofam ecu in, I have a stage 2 t3 .63 and 360 degree bearings on at the mo, do u think this will be ok?,
Mark do u have a number or fb account u can pm me you seem a top kniledgable bloke
Only because I wasted time with trial and error with mine lol
I ended up have a zetec inlet modded for top feed injectors due too room, but I need bonnet spacers, I did this route as it was easier, you could use the inlet you have with a spacer plate (but it won't be perfect) so a modded HO or SO Inlet would be better
And with the tps plug changed too suit it works fine with the ofab too
The turbo doesn't make sense mate, a Stage 2 T3 has a .36 turbine housing and a 50 trim compressor with a 360 degree thrust bearing.... if you have a .63 turbine housing then it's probably a T34 or was it a typo? lol
But either way for 280bhp you will need at least a Stage 3 T3 (.48/55) or a T34 variant.... if you do have a Stage 2 T3 then it's good for about 230-240bhp on a ZT.
