jump leads
I went to buy some new leads but gave up after reading all the specs.
I am after some heavy duty, pretty long (3m) leads that will not get hot and melt at the first turn of the key.
Can you point me in the right direction.
Many thanks.
Many thanks.
What are they for starting? if you wont heavy duty then look at the amp rating the higher the better! 600amp ones will be more than enough for a car! im sure the ones on my daf aid van for doing trucks are 1200
If you cant find the length you need make your own! just get the clamps then 2 lengths of cable at the amp rating you wont
The ones on my brake down van are Anderson plug iver end as they plug into 2 large truck battery's and I've an extention for them.
800amp one will be more than enough to start your car mate
4kg weight is a good sign
http://www.ebay.co.uk/itm/PROFESSION...item58a652c510
http://www.ebay.co.uk/itm/PROFESSION...item565cdbf8eb
Bigger IS better, provided bigger = more copper, and not just PVC as some cheaper leads are.
The Youth.
Sep 30, 2015 09:59 PM
