Heat problem with engine starting
Old Oct 27, 2013 | 06:05 PM
Mk4 Rick's Avatar
Mk4 Rick
Default Heat problem with engine starting
Has anyone ever had a problem with starting there car with a 4 to 1 exhaust right nxt to there starter motor?My starter motor is short in length and its sat right nxt to the exhaust manifold I think there is a couple of mm gap between them both.When its cold its fine but ive noticed the car warms up rather quickly with this manifold on and when it gets red hot in the engine bay the car wont start again.Seems a silly question but worth an ask
Old Oct 27, 2013 | 06:18 PM
Chopshop85's Avatar
Chopshop85
Starter motors don't like heat.
Get the down pipe wrapped.
Old Oct 27, 2013 | 06:28 PM
Mk4 Rick's Avatar
Mk4 Rick
Cheers I will do.Ive been wrecking my head for weeks.Im letting the car cool down just now.i will try starting it again later and if it does I no where I stand.Is there anything else I could do to aid cooling
Old Oct 27, 2013 | 06:43 PM
Chopshop85's Avatar
Chopshop85
What car is it?
And how hot is red hot? Is the coolant temp high?
Old Oct 27, 2013 | 06:47 PM
Mk4 Rick's Avatar
Mk4 Rick
Its red hot the 4 to 1 manifold plays a big part in it.The gauge doesn't take long to reach temperature.i can bend my earth cable when it gets hot as well lol.i don't think bonnet raisers are gonna help on this one.Its a mk4 fiesta but ive fitted a 2 litre blacktop in it
Old Oct 27, 2013 | 06:56 PM
Chopshop85's Avatar
Chopshop85
Hot manifold could be a sign of running lean/too much ingnition advance.
Old Oct 27, 2013 | 07:00 PM
jamie's's Avatar
jamie's
what he said
but it was a common problem with cvh's years ago, but not to the extent your experiencing
Old Oct 27, 2013 | 07:03 PM
Mk4 Rick's Avatar
Mk4 Rick
I will wrap things up and see how it is then
Old Oct 27, 2013 | 07:08 PM
Mk4 Rick's Avatar
Mk4 Rick
The other thing is my battery lives in the boot and im using 4 gauge amp power cable should I be using anything thicker
Old Oct 27, 2013 | 08:56 PM
studabear's Avatar
studabear
Can you not fit a rear starter gearbox?
Old Oct 27, 2013 | 10:29 PM
Mk4 Rick's Avatar
Mk4 Rick
Hi I do plan on fitting a rear starter gearbox at some point.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
ekjim
Aug 17, 2015 08:57 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
Old ford
Jul 31, 2015 06:50 AM
