Can somebody help me?? Danger mk3 fezzie:/
Old Oct 24, 2013 | 11:50 AM
Jamiemk3's Avatar
Jamiemk3
Exclamation Can somebody help me?? Danger mk3 fezzie:/
Hi guys! Quick question, ive had this problem with my mk3 fiesta, everytime i touch the throttle or change gears or brake my car is severly throwing me either to the right or left.. i have no idea whats doing this? Maybe mounts? balancing shaft? track rod end? Has anybody had this before very dangerous me driving it but won't have a chance too look at until saturday and am constantly shitting myself!!
All advice is highly appreciated! Thanks
Old Oct 24, 2013 | 12:00 PM
BLU's Avatar
BLU
BLU is the new black :)
Sounds like you've got a disintegrated wishbone bush to me. Could be other things but that'd be my first port of call.
Old Oct 24, 2013 | 02:31 PM
rs2kgary's Avatar
rs2kgary
i would say your lower arms are fooked did this on my rs2k and is a common fault if you put cheap copy lower arms on
cheeRS gary
Old Oct 24, 2013 | 05:40 PM
Oranoco's Avatar
Oranoco
Another vote for lower arms, only use OEM as all pattern arms I have found to be utter shit.
Old Oct 24, 2013 | 05:48 PM
Turboboy67's Avatar
Turboboy67
It will either be lower arms or engine/gearbox mounts.
Old Oct 25, 2013 | 08:24 AM
Jamiemk3's Avatar
Jamiemk3
Haven't had a look at the wishbone yet.. my rear engine mount is the only mount which is a bit dead if i'm honest, it's very lose so will be replacing that saturday as well as track rod end, whole set of tyres etc as my tread is very low and uneven so bought new ones but just wondering is there a slight possibility of tread of tyres causing this as theyre uneven and may be following the road?
Old Oct 25, 2013 | 08:45 AM
chink's Avatar
chink
sounds like bottom arms to me
Old Oct 25, 2013 | 09:21 AM
Oranoco's Avatar
Oranoco
More likely to be uneven tyre wear is the result of something fucked.
Old Oct 25, 2013 | 09:46 AM
ste1806's Avatar
ste1806
+1 for lower arms
mk3ste
Oct 17, 2021 10:09 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Steve Escos
Oct 1, 2015 06:57 AM
liamT74
Sep 23, 2015 10:24 PM
