s2 problems
Old Oct 20, 2013 | 06:48 PM
70z28's Avatar
70z28
Default s2 problems
Hi all I have bit of a problem with my s2 turbo an was woundering if someone can hopefully point me in the right direction its a starting problem the car starts for few seconds then cuts out an wont start again unless I push the metering unit flap down then it fires straight up any ideas??
Old Oct 20, 2013 | 06:50 PM
Oranoco's Avatar
Oranoco
Check the solid breather pipe that passes round the back of the engine to the metering unit. Have seen these damaged and cause all sorts of problems
Old Oct 20, 2013 | 07:05 PM
70z28's Avatar
70z28
Thanks I will check that tomorrow anything els I need to look out for
Old Oct 20, 2013 | 07:44 PM
stephenbatey's Avatar
stephenbatey
Be the metering head mate so it's a new one or ditch it for an efi setup
Old Oct 20, 2013 | 08:01 PM
70z28's Avatar
70z28
I have a spair so al try it after ive checked that pipe could it just be a sensor or need setting up because when its worm it starts fine
Old Oct 28, 2013 | 08:23 PM
70z28's Avatar
70z28
Ive checked the pipe round the back of the engine an its fine an ive also swoped the metering unit but its still the same it just runs abit longer when I 1st start it I dont know what to do with it next
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
