X type 2.0tdi injector pump code
Old Oct 14, 2013 | 07:18 PM
russ rs's Avatar
russ rs
Default X type 2.0tdi injector pump code
Hi lads please can u help.
I have 2004 jag x type 2.0tdi (euro3) engine
I have have the glow plug come on flashing and has had
A code come up PO251 injector pump
Metering control A.
Can anyone help with what can cause this?
Thanks.
Old Oct 14, 2013 | 07:24 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Cam sensor? Injector? Pressure sensor?
Old Oct 14, 2013 | 07:28 PM
russ rs's Avatar
russ rs
Yea I thought of injectors gonna have to get leak test done to sort. Hope not bloody pump
Old Oct 14, 2013 | 07:38 PM
gingerturbo
Is it common rail on that engine or idivually fed injectors, also check the cam sensor is pulsating in sync with the crank sensor
Old Oct 14, 2013 | 07:41 PM
russ rs's Avatar
russ rs
Fed individually from rail mate.
Old Oct 14, 2013 | 07:45 PM
gingerturbo
Could be an injector failing under pressure
Old Oct 14, 2013 | 08:18 PM
russ rs's Avatar
russ rs
Yea just found fuel around number3 injector
Got new fuel return pipes
Old Oct 14, 2013 | 08:20 PM
gingerturbo
That's good news then,
Old Oct 14, 2013 | 10:16 PM
GVK.'s Avatar
GVK.
Do a search on here for that code, loads of threads about it.
JK12
33
Apr 26, 2021 12:09 PM
Nov 3, 2015 04:08 PM
15
Oct 7, 2015 03:43 PM
SteveyDee
Aug 25, 2015 07:48 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
