IB5 and S2 LSD????
Old Oct 13, 2013 | 08:33 PM
GINGExR2 T's Avatar
GINGExR2 T
Default IB5 and S2 LSD????
Looking for a yes or no really, am I right in saying that the S2 LSD fit's straight into the IB5 box?????
Got a spare IB5 box and spare diff sat in the garage so thought I'd chuck the two together for my cabby turbo.
Ginger
Old Oct 14, 2013 | 09:02 AM
rsmark86's Avatar
rsmark86
As far as I heard your right
It's a s1 diff that does not fit
I'm looking for a ib5 with LSD
Old Oct 14, 2013 | 08:53 PM
xrmalin's Avatar
xrmalin
It does bolt straight in as long as it's the 8 bolt hole mounting to the crown wheel out of a series two.
Make sure you use the crown wheel out of the ib5 & bolt your LSD to that & build your box back up.
I've built one ib5 out of an escort Gti which is going to go in my car and I'm going to be doing another one out of a puma for a friend in the next few weeks.
Old Oct 15, 2013 | 07:18 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Not quite straight in, you need to grind a little off the LSD or it won't fit the IB5 crown wheel.
Old Oct 15, 2013 | 08:32 PM
GINGExR2 T's Avatar
GINGExR2 T
Originally Posted by xrmalin
It does bolt straight in as long as it's the 8 bolt hole mounting to the crown wheel out of a series two. .
Yer it's an 8 bolt S2 diff
I haven't got the box apart yet, but from memory the diff sit in a recess in the crown wheel yer!!! how much has to come off the diff mate???
Cheers for the other reply's
Ginger
Old Oct 16, 2013 | 04:36 PM
xrmalin's Avatar
xrmalin
Mine didn't it sat straight in flush & flat against the crown wheel
Old Oct 16, 2013 | 05:25 PM
Straight_4_N/a's Avatar
Straight_4_N/a
different ib5s use different size parts. ie 1.7 puma ib5 uses bigger thicker items than the say 1.25 fiesta ib5.
So its down to which ib5 your going to fit the erst s2 diff into.
Old Oct 16, 2013 | 05:56 PM
Chopshop85's Avatar
Chopshop85
+1
I used a mk5 diesel FD and the S2 LSD fit no problem.
However, I was planning to use a puma 1.7 FD but the recess is about 2mm in diameter smaller due to it being thicker.
Old Oct 16, 2013 | 06:03 PM
xrmalin's Avatar
xrmalin
Mine was out of an escort Gti which dropped straight in but my mates got a ka box for me to put his diff in so I may have to give that a fettle
Old Oct 16, 2013 | 06:57 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Only needs about 1m taking off if it doesn't fit.
I've never used 1.7 Puma or Escort GTi box's as the ratio's are IMO too close for FI applications.
Old Oct 16, 2013 | 08:28 PM
xrmalin's Avatar
xrmalin
I'll be alright then because mines going on a n/a 2.1 Zetec it's the ka that's going on a Zetec turbo
Old Oct 16, 2013 | 08:44 PM
james kiely's Avatar
james kiely
guys has a rs2000 mk5 got one of these ib5 boxes or a lsd as standard?
Old Oct 17, 2013 | 08:49 AM
Karlos G's Avatar
Karlos G
Balls Deep!
RS2000 is an MTX IIRC.
Old Oct 17, 2013 | 11:36 AM
james kiely
cheers karlos ,are the mtx any good ?
Old Oct 18, 2013 | 03:54 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes mate will take whatever you throw at them pretty much.
Old Oct 24, 2013 | 03:47 PM
GINGExR2 T's Avatar
GINGExR2 T
The code on my IB5 is 96WT-7F096-EA I've done a goggle search and it's from a Mk3 1.1 OHV, anyone have any info on ratio's for this box??????
Cheers,
Ginger
Old Oct 25, 2013 | 09:09 PM
xrmalin's Avatar
xrmalin
Just as a little side note for future reference the diff needs a slight skim off it to fit an ib5 ka crown wheel
Old Oct 26, 2013 | 10:16 AM
GINGExR2 T's Avatar
GINGExR2 T
Off the mating face or the otter circumference mate?????? I'm guessing the circumference yer!
Ginger
Old Oct 26, 2013 | 05:49 PM
xrmalin's Avatar
xrmalin
Ginger
Circumference mate.
Also check the inside of the crown wheel before you bolt the diff to it as mine had a slight burr on the inside which I didn't spot straight out & it was causing the diff to pick up ever so slightly & not sit quiet square.
TPM961
Jan 15, 2018 10:50 AM
mk1turboestate
Dec 2, 2015 08:31 PM
155lee
Oct 24, 2015 11:11 AM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
