Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Oil Filter Wrenches. Which do you find the best?
Old Oct 13, 2013 | 03:59 PM
Wood5tock's Avatar
Wood5tock
Escort Mk4 Goodness
Default Oil Filter Wrenches. Which do you find the best?
Over a fair few years working on my own (and a few others) motors I have done a few oil changes in my time and the perennial question keeps coming up!
What's the best device to remove an oil filter?
I have over the years tried quite a few such as;
• Cheapo chain ones - crap & slippage
• chain wrench with a ratchet - slippage & awkward
• strap wrench with a ratchet - slippage & awkward
• filter pliers - pretty good but needs room to move
I believe some form of wrench that uses a ratchet is the way to go but which one?
Been looking at the "self tightening" three legged ones as they look pretty good.
Also been looking at the cup type, but do these work on canisters with flats as well as flutes at the bottom?
So there you go, any proven methods greatly relieved. Oh apart from the dirty great screwdriver through the side trick
Old Oct 13, 2013 | 04:58 PM
GVK.'s Avatar
GVK.
Depends on the car,working in the trade one tool won't fit all!
I have the 2 of the band type that 'self-tighten' but they don't work on the smaller filters.
3 legged 'claw' type for filters that hang down vertically.
Proper VAG 'cup' type for Err VAG diesels.
Big water pump pliers for anything else.
Lot of the Ford/Hyundai stuff (diesels) just have a 27mm hex where a normal socket is used.
Old Oct 13, 2013 | 05:16 PM
RichieST's Avatar
RichieST
One like this. Look like shite, but grip far better than any chain / strap filter etc will!
Old Oct 13, 2013 | 05:40 PM
GVK.'s Avatar
GVK.
They're the 'band' type I mention, they're ok if you have room to swing the handle round.
Old Oct 13, 2013 | 06:11 PM
Wood5tock's Avatar
Wood5tock
Escort Mk4 Goodness
Thanks for all the replies guys
Guess I should have said its mainly for the Escorts both CVHs and an HCS both with filters on the back of the engine
The only other cars I need to get filters off (at present) is my 04 Vectra which is so easy to change its a dream and my old 1957 Sunbeam mk iii which again is simple
Old Oct 13, 2013 | 06:15 PM
studabear's Avatar
studabear
http://www.ebay.co.uk/itm/FACOM-U-48...item232a633f3d
These are good, sure mine was cheaper.
Also try these, a lot cheaper, my mac version was about Ł20
http://www.ebay.co.uk/itm/ADJUSTABLE...item256d2275df
Old Oct 13, 2013 | 06:21 PM
Wood5tock's Avatar
Wood5tock
Escort Mk4 Goodness
Cheers bud will have at look at the first one, the second is the "filter pliers" I have already but the mk4 Escort yields little room for them
Old Oct 13, 2013 | 06:24 PM
GVK.'s Avatar
GVK.
I'd recommend band type as per RichieST's post, be careful though, they do different sizes, I have a red handled blue-point one that's for large filters (old Transits etc) and a black handled blue-point one for CVH/HCS size filters.
Measure your filter ! http://www.ebay.co.uk/itm/Silverline...item5894405c7f
studabear's Avatar
studabear
You dont get many easier than mk4 escort oil filters
Old Oct 13, 2013 | 06:33 PM
Wood5tock's Avatar
Wood5tock
Escort Mk4 Goodness
Originally Posted by GVK.
I'd recommend band type as per RichieST's post, be careful though, they do different sizes, I have a red handled one that's for large filters (old Transits etc) and a black handled one for CVH/HCS size filters.
I shall have a look at that cheers mate
Old Oct 14, 2013 | 06:58 AM
shalon's Avatar
shalon
i prefer the band type myself i also have a small one for jap style filters
Old Oct 14, 2013 | 08:31 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i have a band one which is good if you have loads of access, but i find my claw type one much better in most situations. the three legged one that is.
Old Oct 15, 2013 | 06:11 PM
gjh's Avatar
gjh
I've always preferred the claw type, followed by the band type, don't like the chain type at all.
Old Oct 15, 2013 | 06:51 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
The strap type for me hands down
Old Oct 16, 2013 | 07:58 AM
daviddunlop83's Avatar
daviddunlop83
I have the chain and recently bought bluepoint oil filter pliers which seem to work great.
Old Oct 24, 2013 | 08:58 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
screw driver and a hammer works every time
Old Oct 24, 2013 | 09:10 PM
Wood5tock's Avatar
Wood5tock
Escort Mk4 Goodness
Only seen it done once. The look on face of the bloke that did it when he realised he had bought the wrong filter was priceless
Old Oct 29, 2013 | 08:54 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Halfords 3 legged removal tool, works 95% of the time if accessible with a ratchet/Extension, can sometimes slip on small filters like subaru but can usually shove something in to pack it up and give it grip.
Old Oct 29, 2013 | 09:44 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
They should be only hand tight anyway. I make sure to lube around the seal of the filter when doing the oil change. I've used the screwdriver method twice, and it's not fun .
cossirob
Aug 29, 2015 03:23 PM
mrmann
Aug 20, 2015 11:24 PM
muffster
Aug 17, 2015 08:17 PM
Roosie
Aug 9, 2015 07:37 AM
1cosworth
Aug 6, 2015 07:53 AM
