Overheating
Old Oct 3, 2013 | 08:52 AM
fitzpodge's Avatar
fitzpodge
Podge
Question Overheating
Alright everyone, I have an s2 with efi conversion, hybrid t3 turbo and its only running at standard boost standard injectors. It has a FRST rad and it just keeps over heating. I thought it just because its hot weather (Australia) but even when it's cool out its doing it. I took out that valve for the water to keep flowing no use ! What's the biggest radiator I can fit into this S2 engine bay ? I've a massive front mount so kind of need a skinny enough rad to get the job done. Cheers !!
Old Oct 3, 2013 | 09:01 AM
studabear's Avatar
studabear
Is your cooling fan operating?
Old Oct 3, 2013 | 09:08 AM
matthart's Avatar
matthart
Hybrid turbo will flow more air at the same boost level, so if I presume you're on standard management it's probably running lean and then getting hot.
Also, isn't a Fiesta rad smaller? Could be something that simple.
The valve you mention, do you mean the thermostat? If so, chuck that into a saucepan and heat it up. If it opens just before the water is boiling it's fine and you should put it back.
Old Oct 3, 2013 | 04:07 PM
Karlos G's Avatar
Karlos G
Balls Deep!
A T3 was never fitted to EFI (Fiesta) RS Turbo's so even a standard T3 will be too much for standard injectors (blue) and ECU calibration, Matt's for example ran lean after 3500rpm at 7psi of boost.
Old Oct 3, 2013 | 04:35 PM
studabear's Avatar
studabear
A mate of mine is running a 2.0zt on frst management that is standard, he melted his forged bottom end
Old Nov 4, 2013 | 03:41 PM
arfurski's Avatar
arfurski
Get the 82 degree thermostat, cold air feed to the air filter, make sure u have the fan on the rad n not the intercooler n, if u can, cut the bumper for better air flow. Give that a go. Failing that, bigger injectors and a remap. I bought a stainless direnza rad and a full size RMD intercooler. Im running near 190bhp and even after a ragging for half an hour or so, the gauge doesnt move above halfway.
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Ade
Feb 8, 2007 05:11 PM
kurdt5
Jul 17, 2006 03:01 PM
fiestaturbo1984
Feb 19, 2006 03:51 PM
woodz77
13
Nov 6, 2005 03:02 PM
