Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
dmf to smf
Old Sep 30, 2013 | 05:16 PM
undie's Avatar
undie
Default dmf to smf
hi all
does anyone on here know if there is a conversion kit from dual mass flywheel to solid mass flywheel to fit my 2002 1.8 turbo di tddi
Old Sep 30, 2013 | 08:24 PM
uruk hai's Avatar
uruk hai
I think the TDDI has a solid flywheel so perhaps your car is a TDCI in which case there is a solid conversion. If you have a bit of a search online you'll find a few conversion kits.
Old Sep 30, 2013 | 08:40 PM
GVK.'s Avatar
GVK.
Transit Connects even the TDCI don't have a DMF. So use a flywheel & clutch for one of those.
I found this out the hard way, had a Connect with a running fault, Ford technical put it down to the DMF, Imagine my suprise when I took the 'box out to find a solid flywheel!!
Edit - It appears as above the TDDI does have a solid flywheel.
Old Oct 1, 2013 | 08:23 PM
undie's Avatar
undie
I bet you were surprised anyway the problem I have got is a nasty rattle coming from the gear box end ,this all started last September its not got any louder or worse ...took it to mr clutch they said that's your dmf mate ok I said thanks ....took it to a friends brother in law who has his own garage and he,s an old school mechanic ,even he said its your dmf ...when the engine is idling its noisy ,I press the clutch pedal in it stops ...from what you said gary im wondering if its my gearbox .....as for the flywheels im am now confused
and yes the transit connect has got the same engine as my focus......wonder if that noise is the layshaft in the gearbox ???
Old Oct 1, 2013 | 10:18 PM
GVK.'s Avatar
GVK.
Some checks.
Press the clutch about an inch or two, and start the engine, then stop it.
If it's a DMF and it's failing, you'll feel a 'kick back' under your foot from the oscillations of the DMF elements.
Also if you start/switch off can you hear or feel any rattles as the engine fires up or when it shuts off?
Are there any vibrations coming through the car as you accelerate?
Make sure gearbox oil level is ok, it could be a gearbox noise of course.
Old Oct 1, 2013 | 10:32 PM
Harryh24's Avatar
Harryh24
read it again more like input shaft bearing if it doesn't have dmf
Old Oct 2, 2013 | 06:23 PM
undie's Avatar
undie
Originally Posted by GVK.
Some checks.
no kick back ..yea got rattles on start up and stop but its done for a while now ..no vibration on acceleration ...got a piece of wood and had a listen noise is more from the right hand side of gearbox
Stu1978
Ford Focus RS
24
Oct 5, 2023 09:09 AM
Flateric_2002
Sep 15, 2015 08:41 AM
Rossy43
Dec 21, 2011 09:21 PM
